[petsc-users] which version of openmpi for petsc-3.1?
    Satish Balay
    balay at mcs.anl.gov
    Wed Jan  5 10:15:06 CST 2011
--download-PACKAGE=PACKAGE.tar.gz usually works only with the
specified version with the URL listed in the corresponding PACKAGE.py
However with MPI - you can install any impl/version separately with
your desired compilers [and not use --download-mpich or
--download-openmpi], and then configure PETSc with mpicc/mpif90 etc
from this install.
Satish
On Wed, 5 Jan 2011, Jed Brown wrote:
> Just use the most recent version unless you have a reason not to. PETSc does
> not depend on any specific versions (or implementations) of MPI.
> On Jan 5, 2011 7:55 AM, "Klaij, Christiaan" <C.Klaij at marin.nl> wrote:
> The manual states:
> "If one had to download a compatible external package manually, then the URL
> for this package is listed in configure source for this package. For
> example, check config/PETSc/packages/SuperLU.py for the url for download
> this package."
> But I cannot find anything like OpenMPI.py... Which version should I
> download?
> Chris
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
