[petsc-users] problem to build PETCS with	Window-Intel_mkl_blas_lapack_mpi
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Feb 25 08:24:07 CST 2011
> --with-blac-lapack-dir
should be --with-blas-lapack-dir
If it fails after rerunning then please send the resulting file configure.log to petsc-maint at mcs.anl.gov
   Barry
On Feb 25, 2011, at 6:24 AM, Hung Thanh Nguyen wrote:
> Hi all
> I am new PETSC using. I am try to install PETSc on Window-Intel-MKL. I am not sure how to link PETSc with intel-mkl-blac-lapack-mpi ? I try :
> $./config/configure.py –with-vendor-compilers=intel \ --with-blac-lapack-dir=/opt/intel/mkl/11.1/067/ia32/lib \ --with-mpi-dir=/opt/intel/mkl//11.1/067/ia32/lib
> And I got the error-message : UNABLE to CONFIGURE with GIVEN OPTIONS
> You must specify a path for MPI with –mpi-dir=<directory>
> If you do not want MPI, then given –with-mpi=0
> Best Regards
> Hung T. Nguyen
