[petsc-users] problem to build PETCS with Window-Intel_mkl_blas_lapack_mpi
Hung Thanh Nguyen
hung.thanh.nguyen at petrell.no
Fri Feb 25 06:24:32 CST 2011
Hi all
I am new PETSC using. I am try to install PETSc on Window-Intel-MKL. I am not sure how to link PETSc with intel-mkl-blac-lapack-mpi ? I try :
$./config/configure.py -with-vendor-compilers=intel \ --with-blac-lapack-dir=/opt/intel/mkl/11.1/067/ia32/lib \ --with-mpi-dir=/opt/intel/mkl//11.1/067/ia32/lib
And I got the error-message : UNABLE to CONFIGURE with GIVEN OPTIONS
You must specify a path for MPI with -mpi-dir=<directory>
If you do not want MPI, then given -with-mpi=0
Best Regards
Hung T. Nguyen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110225/3baf4a6d/attachment.htm>
