[petsc-users] general VecScatter from MPI to MPI
    Matthew Knepley
    knepley at gmail.com
    Thu Feb 17 11:22:46 CST 2011
On Thu, Feb 17, 2011 at 11:18 AM, Ethan Coon <ecoon at lanl.gov> wrote:
> On Thu, 2011-02-17 at 10:35 -0600, Matthew Knepley wrote:
> > On Thu, Feb 17, 2011 at 10:06 AM, Ethan Coon <ecoon at lanl.gov> wrote:
> >         So I thought I understood how VecScatters worked, but
> >         apparently not.
> >         Is it possible to create a general VecScatter from an
> >         arbitrarily
> >         partitioned (MPI) Vec to another arbitrarily partitioned (MPI)
> >         Vec with
> >         the same global sizes (or same global IS sizes) but different
> >         local
> >         sizes?  Shouldn't this just be a matter of relying upon the
> >         implied
> >         LocalToGlobalMapping?
> > No, the way you have to do this is to map a global Vec to a bunch of
> > sequential local Vecs with the sizes you want. This is also how we map
> > to overlapping arrays.
> So effectively I need two scatters -- a scatter from the global Vec to
> the sequential local Vecs, then a scatter (which requires no
> communication) to inject the sequential Vecs into the new global Vec?
No, just wrap up the pieces of your global Vec as local Vecs and scatter
straight into that storage using VecCreateSeqWithArray().
   Matt
> Why?  Am I missing something that makes the MPI to MPI scatter ill-posed
> as long as the global sizes (but not local sizes) are equal?
> This is mostly curiosity on my part... I think I have to do two scatters
> anyway since I'm working with multiple comms -- scatter from an MPI Vec
> on one sub-comm into local, sequential Vecs, then scatter those
> sequential Vecs into an MPI Vec on PETSC_COMM_WORLD. That's the correct
> model for injecting an MPI Vec on one comm into an MPI Vec on
> PETSC_COMM_WORLD, correct?
> Ethan
> >    Matt
> >         See below snippet (and its errors):
> >         Ethan
> >         Vec vA
> >         Vec vB
> >         VecScatter scatter_AB
> >         PetscInt np
> >         PetscInt rank
> >         PetscErrorCode ierr
> >         if (rank.eq.0) np = 3
> >         if (rank.eq.1) np = 1
> >         call VecCreateMPI(PETSC_COMM_WORLD, 2, PETSC_DETERMINE, vA,
> >         ierr)
> >         call VecCreateMPI(PETSC_COMM_WORLD, np, PETSC_DETERMINE, vB,
> >         ierr)
> >         call VecScatterCreate(vA, PETSC_NULL_OBJECT, vB,
> >         PETSC_NULL_OBJECT,
> >                scatter_AB, ierr)
> >         $> mpiexec -n 2 ./test
> >         [0]PETSC ERROR: --------------------- Error Message
> >         [0]PETSC ERROR: Nonconforming object sizes!
> >         [0]PETSC ERROR: Local scatter sizes don't match!
> >         [0]PETSC ERROR:
> >         [1]PETSC ERROR: --------------------- Error Message
> >         [1]PETSC ERROR: Nonconforming object sizes!
> >         [1]PETSC ERROR: Local scatter sizes don't match!
> >         [0]PETSC ERROR: Petsc Development HG revision:
> >         5dbe1264252fb9cb5d8e033d620d18f7b0e9111f  HG Date: Fri Feb 11
> >         15:44:04
> >         2011 -0600
> >         [0]PETSC ERROR: See docs/changes/index.html for recent
> >         updates.
> >         [0]PETSC ERROR: See docs/faq.html for hints about trouble
> >         shooting.
> >         [0]PETSC ERROR: See docs/index.html for manual pages.
> >         [0]PETSC ERROR:
> >         [0]PETSC ERROR: ./test on a linux-gnu named tama1 by ecoon Thu
> >         Feb 17
> >         08:14:57 2011
> >         [0]PETSC ERROR: Libraries linked
> >         from
> /packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared/lib
> >         [0]PETSC ERROR: Configure run at Fri Feb 11 16:15:14 2011
> >         [0]PETSC ERROR: Configure options --with-debugging=1
> --prefix=/packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared
> --download-mpich=1 --download-ml=1 --download-umfpack=1
> --with-blas-lapack-dir=/usr/lib --download-parmetis=yes
> PETSC_ARCH=linux-gnu-c-debug-shared --with-clanguage=c --download-hypre=1
> --with-shared-libraries=1 --download-hdf5=1
> >         [0]PETSC ERROR:
> >         [0]PETSC ERROR: VecScatterCreate() line 1432 in
> >         src/vec/vec/utils/vscat.c
> >         application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
> >         [cli_0]: aborting job:
> >         [1]PETSC ERROR: APPLICATION TERMINATED WITH THE EXIT STRING:
> >         Hangup
> >         (signal 1)
> >         Ethan Coon
> >         Post-Doctoral Researcher
> >         Applied Mathematics - T-5
> >         Los Alamos National Laboratory
> >         505-665-8289
> >         http://www.ldeo.columbia.edu/~ecoon/
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> Ethan Coon
> 505-665-8289
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110217/64f4c015/attachment.htm>
