[petsc-users] general VecScatter from MPI to MPI
    Ethan Coon
    ecoon at lanl.gov
    Thu Feb 17 11:31:06 CST 2011
>         So effectively I need two scatters -- a scatter from the
>         global Vec to
>         the sequential local Vecs, then a scatter (which requires no
>         communication) to inject the sequential Vecs into the new
>         global Vec?
> No, just wrap up the pieces of your global Vec as local Vecs and
> scatter
> straight into that storage using VecCreateSeqWithArray().
Ah ha!  Thanks,
Ethan
>    Matt
>         Why?  Am I missing something that makes the MPI to MPI scatter
>         ill-posed
>         as long as the global sizes (but not local sizes) are equal?
>         This is mostly curiosity on my part... I think I have to do
>         two scatters
>         anyway since I'm working with multiple comms -- scatter from
>         an MPI Vec
>         on one sub-comm into local, sequential Vecs, then scatter
>         those
>         sequential Vecs into an MPI Vec on PETSC_COMM_WORLD. That's
>         the correct
>         model for injecting an MPI Vec on one comm into an MPI Vec on
>         PETSC_COMM_WORLD, correct?
>         Ethan
>         >    Matt
>         >         See below snippet (and its errors):
>         >         Ethan
>         >         Vec vA
>         >         Vec vB
>         >         VecScatter scatter_AB
>         >         PetscInt np
>         >         PetscInt rank
>         >         PetscErrorCode ierr
>         >         if (rank.eq.0) np = 3
>         >         if (rank.eq.1) np = 1
>         >         call VecCreateMPI(PETSC_COMM_WORLD, 2,
>         PETSC_DETERMINE, vA,
>         >         ierr)
>         >         call VecCreateMPI(PETSC_COMM_WORLD, np,
>         PETSC_DETERMINE, vB,
>         >         ierr)
>         >         call VecScatterCreate(vA, PETSC_NULL_OBJECT, vB,
>         >         PETSC_NULL_OBJECT,
>         >                scatter_AB, ierr)
>         >         $> mpiexec -n 2 ./test
>         >         [0]PETSC ERROR: --------------------- Error Message
>         >         [0]PETSC ERROR: Nonconforming object sizes!
>         >         [0]PETSC ERROR: Local scatter sizes don't match!
>         >         [0]PETSC ERROR:
>         >         [1]PETSC ERROR: --------------------- Error Message
>         >         [1]PETSC ERROR: Nonconforming object sizes!
>         >         [1]PETSC ERROR: Local scatter sizes don't match!
>         >         [0]PETSC ERROR: Petsc Development HG revision:
>         >         5dbe1264252fb9cb5d8e033d620d18f7b0e9111f  HG Date:
>         Fri Feb 11
>         >         15:44:04
>         >         2011 -0600
>         >         [0]PETSC ERROR: See docs/changes/index.html for
>         recent
>         >         updates.
>         >         [0]PETSC ERROR: See docs/faq.html for hints about
>         trouble
>         >         shooting.
>         >         [0]PETSC ERROR: See docs/index.html for manual
>         pages.
>         >         [0]PETSC ERROR:
>         >         [0]PETSC ERROR: ./test on a linux-gnu named tama1 by
>         ecoon Thu
>         >         Feb 17
>         >         08:14:57 2011
>         >         [0]PETSC ERROR: Libraries linked
>         from /packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared/lib
>         >         [0]PETSC ERROR: Configure run at Fri Feb 11 16:15:14
>         2011
>         >         [0]PETSC ERROR: Configure options --with-debugging=1
>         --prefix=/packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared --download-mpich=1 --download-ml=1 --download-umfpack=1 --with-blas-lapack-dir=/usr/lib --download-parmetis=yes PETSC_ARCH=linux-gnu-c-debug-shared --with-clanguage=c --download-hypre=1 --with-shared-libraries=1 --download-hdf5=1
>         >         [0]PETSC ERROR:
>         >         [0]PETSC ERROR: VecScatterCreate() line 1432 in
>         >         src/vec/vec/utils/vscat.c
>         >         application called MPI_Abort(MPI_COMM_WORLD, 60) -
>         process 0
>         >         [cli_0]: aborting job:
>         process 0
>         >         [1]PETSC ERROR: APPLICATION TERMINATED WITH THE EXIT
>         STRING:
>         >         Hangup
>         >         (signal 1)
>         >         Ethan Coon
>         >         Post-Doctoral Researcher
>         >         Applied Mathematics - T-5
>         >         Los Alamos National Laboratory
>         >         505-665-8289
>         >         http://www.ldeo.columbia.edu/~ecoon/
>         > What most experimenters take for granted before they begin
>         their
>         > experiments is infinitely more interesting than any results
>         to which
>         > their experiments lead.
>         > -- Norbert Wiener
>         Ethan Coon
>         505-665-8289
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Ethan Coon
505-665-8289
