[petsc-users] general VecScatter from MPI to MPI
Ethan Coon ecoon at lanl.gov
Thu Feb 17 11:18:27 CST 2011
On Thu, 2011-02-17 at 10:35 -0600, Matthew Knepley wrote:
> On Thu, Feb 17, 2011 at 10:06 AM, Ethan Coon <ecoon at lanl.gov> wrote:
>         So I thought I understood how VecScatters worked, but
>         apparently not.
>         Is it possible to create a general VecScatter from an
>         arbitrarily
>         partitioned (MPI) Vec to another arbitrarily partitioned (MPI)
>         Vec with
>         the same global sizes (or same global IS sizes) but different
>         local
>         sizes?  Shouldn't this just be a matter of relying upon the
>         implied
>         LocalToGlobalMapping?
> No, the way you have to do this is to map a global Vec to a bunch of
> sequential local Vecs with the sizes you want. This is also how we map
> to overlapping arrays.
So effectively I need two scatters -- a scatter from the global Vec to
the sequential local Vecs, then a scatter (which requires no
communication) to inject the sequential Vecs into the new global Vec?
Why?  Am I missing something that makes the MPI to MPI scatter ill-posed
as long as the global sizes (but not local sizes) are equal?
This is mostly curiosity on my part... I think I have to do two scatters
anyway since I'm working with multiple comms -- scatter from an MPI Vec
on one sub-comm into local, sequential Vecs, then scatter those
sequential Vecs into an MPI Vec on PETSC_COMM_WORLD. That's the correct
model for injecting an MPI Vec on one comm into an MPI Vec on
PETSC_COMM_WORLD, correct?
Ethan
>    Matt
>         See below snippet (and its errors):
>         Ethan
>         Vec vA
>         Vec vB
>         VecScatter scatter_AB
>         PetscInt np
>         PetscInt rank
>         PetscErrorCode ierr
>         if (rank.eq.0) np = 3
>         if (rank.eq.1) np = 1
>         call VecCreateMPI(PETSC_COMM_WORLD, 2, PETSC_DETERMINE, vA,
>         ierr)
>         call VecCreateMPI(PETSC_COMM_WORLD, np, PETSC_DETERMINE, vB,
>         ierr)
>         call VecScatterCreate(vA, PETSC_NULL_OBJECT, vB,
>         PETSC_NULL_OBJECT,
>                scatter_AB, ierr)
>         $> mpiexec -n 2 ./test
>         [0]PETSC ERROR: --------------------- Error Message
>         [0]PETSC ERROR: Nonconforming object sizes!
>         [0]PETSC ERROR: Local scatter sizes don't match!
>         [0]PETSC ERROR:
>         [1]PETSC ERROR: --------------------- Error Message
>         [1]PETSC ERROR: Nonconforming object sizes!
>         [1]PETSC ERROR: Local scatter sizes don't match!
>         [0]PETSC ERROR: Petsc Development HG revision:
>         5dbe1264252fb9cb5d8e033d620d18f7b0e9111f  HG Date: Fri Feb 11
>         15:44:04
>         2011 -0600
>         [0]PETSC ERROR: See docs/changes/index.html for recent
>         updates.
>         [0]PETSC ERROR: See docs/faq.html for hints about trouble
>         shooting.
>         [0]PETSC ERROR: See docs/index.html for manual pages.
>         [0]PETSC ERROR:
>         [0]PETSC ERROR: ./test on a linux-gnu named tama1 by ecoon Thu
>         Feb 17
>         08:14:57 2011
>         [0]PETSC ERROR: Libraries linked
>         from /packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared/lib
>         [0]PETSC ERROR: Configure run at Fri Feb 11 16:15:14 2011
>         [0]PETSC ERROR: Configure options --with-debugging=1
>         --prefix=/packages/petsc/petsc-dev3.0-mpich2-local-gcc-4.3.3/debug-shared --download-mpich=1 --download-ml=1 --download-umfpack=1 --with-blas-lapack-dir=/usr/lib --download-parmetis=yes PETSC_ARCH=linux-gnu-c-debug-shared --with-clanguage=c --download-hypre=1 --with-shared-libraries=1 --download-hdf5=1
>         [0]PETSC ERROR:
>         [0]PETSC ERROR: VecScatterCreate() line 1432 in
>         src/vec/vec/utils/vscat.c
>         application called MPI_Abort(MPI_COMM_WORLD, 60) - process 0
>         [cli_0]: aborting job:
>         [1]PETSC ERROR: APPLICATION TERMINATED WITH THE EXIT STRING:
>         Hangup
>         (signal 1)
>         Ethan Coon
>         Post-Doctoral Researcher
>         Applied Mathematics - T-5
>         Los Alamos National Laboratory
>         505-665-8289
>         http://www.ldeo.columbia.edu/~ecoon/
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Ethan Coon
505-665-8289
