[petsc-users] Removing petsc
Wed Feb 16 21:20:35 CST 2011
  If you just used different PETSC_ARCH variables like arch-complex arch-opt etc  you can just delete those directories and that will remove everything related to them.
   Barry
On Feb 16, 2011, at 9:18 PM, Golam Rabbani wrote:
> Hi,
> I am new to petsc and also new to linux/unix environment.
> Recently I started converting a matlab nanodevice simulaiton code into a c code using petsc and have done most of the converting.
> But in the process I have installed petsc 4/5 times with different configuration options (real, complex, with blopex, etc). Now that I
> do not need some of them,  I want to uninstall them. Can I simply delete the unwanted versions (all the versions are in separate folders)?
> Please advise me if something different is needed.
> Thanks in advance,
> Golam
