[petsc-users] Removing petsc
Golam Rabbani
mgrabbani at gmail.com
Wed Feb 16 21:18:21 CST 2011
I am new to petsc and also new to linux/unix environment.
Recently I started converting a matlab nanodevice simulaiton code into a c
code using petsc and have done most of the converting.
But in the process I have installed petsc 4/5 times with different
configuration options (real, complex, with blopex, etc). Now that I
do not need some of them, I want to uninstall them. Can I simply delete the
unwanted versions (all the versions are in separate folders)?
Please advise me if something different is needed.
Thanks in advance,
Golam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110216/1ed590ed/attachment-0001.htm>
