[petsc-users] Removing petsc
Golam Rabbani mgrabbani at gmail.com
Thu Feb 17 12:22:14 CST 2011
Thanks for reply.
I have not used different PETSC_ARCH; in all the installations it has the
same value of linux-gnu-c-debug, but the different installations are in
completely separate folders and extra packages like lapack, mpi are also
installed separately. Can I delete a folder containing a full installation
and not affect my system?
Thanks
Golam
On Wed, Feb 16, 2011 at 7:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  If you just used different PETSC_ARCH variables like arch-complex arch-opt
> etc  you can just delete those directories and that will remove everything
> related to them.
>   Barry
> On Feb 16, 2011, at 9:18 PM, Golam Rabbani wrote:
> > Hi,
> > I am new to petsc and also new to linux/unix environment.
> > Recently I started converting a matlab nanodevice simulaiton code into a
> c code using petsc and have done most of the converting.
> > But in the process I have installed petsc 4/5 times with different
> configuration options (real, complex, with blopex, etc). Now that I
> > do not need some of them,  I want to uninstall them. Can I simply delete
> the unwanted versions (all the versions are in separate folders)?
> > Please advise me if something different is needed.
> > Thanks in advance,
> > Golam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110217/911b7d05/attachment.htm>
