[petsc-users] performance issue solving multiple linear systems of the same size with the different preconditioning methods
Алексей Рязанов
ram at ibrae.ac.ru
Sat Aug 27 15:58:22 CDT 2011
So. All memory and time issues appeared because of my KSPConvergedTest
function, which calls KSPBuildResidual to monitor true
residual. KSPBuildResidual incorrectly works with memory. As soon as I've
commented the line with KSPBuildResidual, all troubles gone. So now I use
default monitor and have to monitor preconditioned residual. This is
inconvenient for me, but I cant figure out, how can I set up using true
monitor for all methods without any memory or performance leaks. I'll try to
get used t deal with preconditioned norm.
Thank you very much for taking the time to reply to me.
Best regards,
Alexey Ryazanov
______________________________________
Nuclear Safety Institute of Russian Academy of Sciences
27 августа 2011 г. 17:32 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
> Oh BOY! It was all fault of my MyKSPConvergedTest.
> 27 августа 2011 г. 1:29 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
> I have also checked KSPSolve behavior in my other PETSc programs and found
>> the same memory lack
>> 27 августа 2011 г. 0:57 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
>>> Thank you for your response!
>>> I have the memory leak in both my programs. But I don't create plenty of
>>> vectors.
>>> My code looks like:
>>> ***INIT_ALL***
>>> PetscLogStageRegister("Iteration :", &StageNum1);
>>> PetscLogStagePush(StageNum1);
>>> KSPSolve(dKSP, dvec_origRHS, dvec_Solution);
>>> PetscLogStagePop();
>>> ***DESTROY_ALL***
>>> And when I comment (or delete) KSPSolve, the log_summary output is:
>>> Memory usage is given in bytes:
>>> Creations Destructions Memory Descendants' Mem Object Type
>>> Reports information only for process 0.
>>> --- Event Stage 0: Main Stage
>>> 1 1 729472 0 Application Order
>>> 1 1 225452 0 Distributed array
>>> 8 8 1533424 0 Vec
>>> 3 3 2604 0 Vec Scatter
>>> 8 8 613852 0 Index Set
>>> 1 1 221304 0 IS L to G Mapping
>>> 3 3 16603440 0 Matrix
>>> 1 1 832 0 Krylov Solver
>>> 1 1 688 0 Preconditioner
>>> 1 1 448 0 PetscRandom
>>> --- Event Stage 1: Iteration :
>>> When I run the code with KSPSolve instruction, it gives me:
>>> 1 0 0 0 Application Order
>>> 1 0 0 0 Distributed array
>>> 8 17 4963592 0 Vec
>>> 3 2 1736 0 Vec Scatter
>>> 8 12 1425932 0 Index Set
>>> 1 0 0 0 IS L to G Mapping
>>> 3 5 50158132 0 Matrix
>>> 1 2 1664 0 Krylov Solver
>>> 1 2 1440 0 Preconditioner
>>> 0 1 544 0 Viewer
>>> 355 173 64692312 0 Vec
>>> 1 0 0 0 Vec Scatter
>>> 6 2 1024 0 Index Set
>>> 2 0 0 0 Matrix
>>> 1 0 0 0 Krylov Solver
>>> 1 0 0 0 Preconditioner
>>> 2 1 544 0 Viewer
>>> 2011/8/25 Jed Brown <jedbrown at mcs.anl.gov>
>>>> On Tue, Aug 23, 2011 at 02:37, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
>>>>> When i delete the 4-5-6 part of 2nd, 1-2-3 works great! with exact like
>>>>> 1st results.
>>>>> When i delete the 1-2-3 part of 2nd, 4-5-6 works great! with exact like
>>>>> 1st results.
>>>>> All program (1-2-3-4-5-6) works badly.
>>>> From the -log_summary, you have a memory leak (many more vector
>>>> creations than destructions). Try running with -malloc_dump to debug it.
>>>> Perhaps you are creating a vector every time one of your functions is
>>>> called? You should also build --with-debugging=0 when looking at timing
>>>> results. (You can keep it in PETSC_ARCH=linux-gnu-opt.)
>>> Best regards,
>>> Alexey Ryazanov
>> Best regards,
>> Alexey Ryazanov
> Best regards,
> Alexey Ryazanov
Best regards,
Alexey Ryazanov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110828/523856e1/attachment.htm>
