[petsc-users] performance issue solving multiple linear systems of the same size with the different preconditioning methods
    Алексей Рязанов
    ram at ibrae.ac.ru
    Sat Aug 27 08:32:39 CDT 2011
Oh BOY! It was all fault of my MyKSPConvergedTest.
27 августа 2011 г. 1:29 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
> I have also checked KSPSolve behavior in my other PETSc programs and found
> the same memory lack
> 27 августа 2011 г. 0:57 пользователь Алексей Рязанов <ram at ibrae.ac.ru>написал:
>> Thank you for your response!
>> I have the memory leak in both my programs. But I don't create plenty of
>> vectors.
>> My code looks like:
>>   ***INIT_ALL***
>>   PetscLogStageRegister("Iteration  :", &StageNum1);
>>   PetscLogStagePush(StageNum1);
>>   KSPSolve(dKSP, dvec_origRHS, dvec_Solution);
>>   PetscLogStagePop();
>>   ***DESTROY_ALL***
>> And when I comment (or delete) KSPSolve, the log_summary output is:
>> Memory usage is given in bytes:
>> Creations   Destructions     Memory  Descendants' Mem Object Type
>> Reports information only for process 0.
>> --- Event Stage 0: Main Stage
>> 1              1         729472     0   Application Order
>> 1              1         225452     0   Distributed array
>> 8              8       1533424     0   Vec
>> 3              3             2604     0   Vec Scatter
>> 8              8         613852     0   Index Set
>> 1              1         221304     0   IS L to G Mapping
>> 3              3     16603440     0   Matrix
>> 1              1               832     0   Krylov Solver
>> 1              1               688     0   Preconditioner
>> 1              1               448     0   PetscRandom
>> --- Event Stage 1: Iteration  :
>> When I run the code with KSPSolve instruction, it gives me:
>> 1              0            0            0      Application Order
>> 1              0            0            0      Distributed array
>> 8             17      4963592     0      Vec
>> 3              2         1736         0      Vec Scatter
>> 8             12      1425932     0      Index Set
>> 1              0            0            0      IS L to G Mapping
>> 3              5     50158132     0      Matrix
>> 1              2         1664         0      Krylov Solver
>> 1              2         1440         0      Preconditioner
>> 0              1          544          0      Viewer
>> 355        173   64692312     0      Vec
>> 1              0            0            0      Vec Scatter
>> 6              2         1024         0      Index Set
>> 2              0            0            0      Matrix
>> 1              0            0            0      Krylov Solver
>> 1              0            0            0      Preconditioner
>> 2              1          544          0      Viewer
>> 2011/8/25 Jed Brown <jedbrown at mcs.anl.gov>
>>> On Tue, Aug 23, 2011 at 02:37, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
>>>> When i delete the 4-5-6 part of 2nd, 1-2-3 works great! with exact like
>>>> 1st results.
>>>> When i delete the 1-2-3 part of 2nd, 4-5-6 works great! with exact like
>>>> 1st results.
>>>> All program (1-2-3-4-5-6) works badly.
>>> From the -log_summary, you have a memory leak (many more vector creations
>>> than destructions). Try running with -malloc_dump to debug it. Perhaps you
>>> are creating a vector every time one of your functions is called? You should
>>> also build --with-debugging=0 when looking at timing results. (You can keep
>>> it in PETSC_ARCH=linux-gnu-opt.)
>> Best regards,
>> Alexey Ryazanov
>> ______________________________________
>> Nuclear Safety Institute of Russian Academy of Sciences
> Best regards,
> Alexey Ryazanov
Best regards,
Alexey Ryazanov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110827/a25753b4/attachment-0001.htm>
