[petsc-users] Index set with zero size
Jed Brown jed at 59A2.org
Tue Nov 9 05:53:17 CST 2010
On Tue, Nov 9, 2010 at 12:49, Tim Kroeger
<tim.kroeger at cevis.uni-bremen.de>wrote:
> Well, as you know, I'm using PETSc only via libMesh.  Creating a standalone
> PETSc test case is non-trivial for me.  But I'll keep to this and will
> either find out that I did something wrong or produce a test case for you.
> It might be imporant to know that the original matrix is a ShellMatrix.
Yes, this is important.  Check the implementation of MatMultAdd for the
Shell.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101109/b5fa6104/attachment.htm>
