[petsc-users] Index set with zero size
Tim Kroeger
tim.kroeger at cevis.uni-bremen.de
Tue Nov 9 05:49:12 CST 2010
On Tue, 9 Nov 2010, Jed Brown wrote:
> On Tue, Nov 9, 2010 at 12:11, Tim Kroeger <tim.kroeger at cevis.uni-bremen.de> wrote:
> Is it allowed to work with an index set (IS) with size 0?
> Yes.
Good to hear, thank you.
> In particular, using such an index set in VecScatter and MatGetSubMatrix, I am creating the following
> objects:
> v : a vector of size n>0,
> w : a vector of size 0,
> A : a matrix of size n\times0.
> Then I do
> MatMultAdd (A, w, v, v);
> This actually seems to change the value of v, although I supposed it not to do so.
> It sounds like you have a simple test case for this, could you send it?
Well, as you know, I'm using PETSc only via libMesh. Creating a
standalone PETSc test case is non-trivial for me. But I'll keep to
this and will either find out that I did something wrong or produce a
test case for you.
It might be imporant to know that the original matrix is a
ShellMatrix.
Best Regards,
Tim
Dr. Tim Kroeger
CeVis -- Center of Complex Systems and Visualization
University of Bremen tim.kroeger at cevis.uni-bremen.de
Universitaetsallee 29 tim.kroeger at mevis.fraunhofer.de
D-28359 Bremen Phone +49-421-218-7710
Germany Fax +49-421-218-4236
