[petsc-users] Index set with zero size
    Jed Brown
    jed at 59A2.org
    Tue Nov  9 05:28:09 CST 2010
On Tue, Nov 9, 2010 at 12:11, Tim Kroeger
<tim.kroeger at cevis.uni-bremen.de>wrote:
> Is it allowed to work with an index set (IS) with size 0?
Yes.
In particular, using such an index set in VecScatter and MatGetSubMatrix, I
> am creating the following objects:
> v : a vector of size n>0,
> w : a vector of size 0,
> A : a matrix of size n\times0.
> Then I do
> MatMultAdd (A, w, v, v);
> This actually seems to change the value of v, although I supposed it not to
> do so.
It sounds like you have a simple test case for this, could you send it?
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101109/4e705fd6/attachment.htm>
