[petsc-users] configure problems
Dominik Szczerba dominik at itis.ethz.ch
Thu Jul 22 08:58:24 CDT 2010
Many thanks for your precious feedback.
My MPICH install is 64 bit but it seems that for some reason 32 bit VC
compiler is invoked (I have both 32 and 64 installed).
I am clarifying with a local MSVC expert how to control this, will update
you later today.
Dominik
On Thu, Jul 22, 2010 at 3:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> > Files/MPICH2/lib/amd64/msmpi.lib
> Looks like - if win32fe doesn't find the file - it doesn't try to
> convert the path. This is not the cause of his configure failure.
> The primary issue is: [which is much ahead in configure.log]
> sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl
>  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\
> Files/MPICH2/lib/mpi.lib Ws2_32.lib
> Executing:
> /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl  -o
> sh: conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
> referenced in function _main^M
> C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error LNK1120:
> 1 unresolved externals^M
> Here cl is finding the correct library - but not MPI_Init symbol in it.
> For whatever reason - libmpi.lib is not compatible.
> Satish
> On Thu, 22 Jul 2010, Farshid Mossaiby wrote:
> > I doubt 'cl' can interpret Cygwin paths:
> > cl : Command line warning D9002 : ignoring unknown option
> > '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> > Shouldn't win32fe convert this path first?
> > Hope this helps.
> > --- On Wed, 7/21/10, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> > > From: Dominik Szczerba <dominik at itis.ethz.ch>
> > > Subject: Re: [petsc-users] configure problems
> > > To: "PETSc users list" <petsc-users at mcs.anl.gov>
> > > Date: Wednesday, July 21, 2010, 7:01 PM
> > > Coming back to the original problem:
> > > I tried to compile MPICH2 myself
> > > and failed because of wrong version of automake in Cygwin.
> > > I then
> > > installed the Windows binary available on the mpich2
> > > webpage. I
> > > configure petsc with:
> > > $ ./config/configure.py PETSC_DIR=$PWD
> > > PETSC_ARCH=win64-msvc-release
> > > --download-c-blas-lapack=1
> > > --with-mpi-dir='/cygdrive/c/Program
> > > Files/MPICH2' --with-x=0 --with-debugging=0
> > > --with-cc='win32fe cl'
> > > --with-fc=0
> > > to hear at the end (of a very long configuration
> > > process...):
> > > sh:
> > > cl  -o conftest.exe    -MT -wd4996
> > > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > > Executing:
> > > _MPI_Init
> > > error
> > > LNK1120: 1 unresolved externals
> > > Any directions why would the configuration look for a
> > > nonexistent
> > > library? The contents of the installation folder are:
> > > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > > total 808
> > > drwx------+ 1 SYSTEM SYSTEM   4096
> > > 2010-07-21 15:54 .
> > > 2010-07-21 15:54 ..
> > > -rwx------+ 1 SYSTEM SYSTEM   4644
> > > 2010-02-22 17:13 TraceInput.lib
> > > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09
> > > cxx.lib
> > > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11
> > > fmpich2.lib
> > > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13
> > > fmpich2g.lib
> > > -rwx------+ 1 SYSTEM SYSTEM   1936
> > > 2010-02-22 17:13 irlog2rlog.lib
> > > -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30
> > > mpe.lib
> > > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29
> > > mpi.lib
> > > -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30
> > > rlog.lib
> > > Best regards,
> > > Dominik
> > > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org>
> > > wrote:
> > > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley
> > > <knepley at gmail.com>
> > > wrote:
> > > >> This would do you absolutely no good. Even Jed's
> > > thing needs all the
> > > >> information that the configure provides. CMake is
> > > exactly what it
> > > >> says, make. It does no configuration
> > > > This isn't true, CMake isn't a build system at all, it
> > > does
> > > > configuration and produces build files for another
> > > tool (like make or an
> > > > IDE).  I see no point in maintaining duplicate
> > > configuration systems,
> > > > and CMake's scripting language is so attrocious that
> > > "replacing"
> > > > BuildSystem with CMake script would be a disaster.
> > >  It's
> > > > cross-compilation support is also a bit weak, and
> > > there are a pile of
> > > > other things that it does poorly (mostly related to
> > > pathologically
> > > > dysfunctional "Find*.cmake" modules).  That doesn't
> > > mean it isn't useful
> > > > for producing build files.
> > > > Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100722/d54457dc/attachment-0001.htm>
