[petsc-users] configure problems
Thu Jul 22 08:45:46 CDT 2010
> sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> Files/MPICH2/lib/amd64/msmpi.lib
Looks like - if win32fe doesn't find the file - it doesn't try to
convert the path. This is not the cause of his configure failure.
The primary issue is: [which is much ahead in configure.log]
sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\ Files/MPICH2/lib/mpi.lib Ws2_32.lib
Executing: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\ Files/MPICH2/lib/mpi.lib Ws2_32.lib
sh: conftest.obj : error LNK2019: unresolved external symbol _MPI_Init referenced in function _main^M
C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error LNK1120: 1 unresolved externals^M
Here cl is finding the correct library - but not MPI_Init symbol in it.
For whatever reason - libmpi.lib is not compatible.
Satish
On Thu, 22 Jul 2010, Farshid Mossaiby wrote:
> I doubt 'cl' can interpret Cygwin paths:
> cl : Command line warning D9002 : ignoring unknown option
> '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> Shouldn't win32fe convert this path first?
> Hope this helps.
> --- On Wed, 7/21/10, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> > From: Dominik Szczerba <dominik at itis.ethz.ch>
> > Subject: Re: [petsc-users] configure problems
> > To: "PETSc users list" <petsc-users at mcs.anl.gov>
> > Date: Wednesday, July 21, 2010, 7:01 PM
> > Coming back to the original problem:
> > I tried to compile MPICH2 myself
> > and failed because of wrong version of automake in Cygwin.
> > I then
> > installed the Windows binary available on the mpich2
> > webpage. I
> > configure petsc with:
> > $ ./config/configure.py PETSC_DIR=$PWD
> > PETSC_ARCH=win64-msvc-release
> > --download-c-blas-lapack=1
> > --with-mpi-dir='/cygdrive/c/Program
> > Files/MPICH2' --with-x=0 --with-debugging=0
> > --with-cc='win32fe cl'
> > --with-fc=0
> > to hear at the end (of a very long configuration
> > process...):
> > sh:
> > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > Executing:
> > _MPI_Init
> > error
> > Any directions why would the configuration look for a
> > nonexistent
> > library? The contents of the installation folder are:
> > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > total 808
> > drwx------+ 1 SYSTEM SYSTEM   4096
> > 2010-07-21 15:54 .
> > 2010-07-21 15:54 ..
> > -rwx------+ 1 SYSTEM SYSTEM   4644
> > 2010-02-22 17:13 TraceInput.lib
> > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09
> > cxx.lib
> > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11
> > fmpich2.lib
> > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13
> > fmpich2g.lib
> > -rwx------+ 1 SYSTEM SYSTEM   1936
> > 2010-02-22 17:13 irlog2rlog.lib
> > -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30
> > mpe.lib
> > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29
> > mpi.lib
> > -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30
> > rlog.lib
> > Best regards,
> > Dominik
> > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org>
> > wrote:
> > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley
> > <knepley at gmail.com>
> > wrote:
> > >> This would do you absolutely no good. Even Jed's
> > thing needs all the
> > >> information that the configure provides. CMake is
> > exactly what it
> > >> says, make. It does no configuration
> > > This isn't true, CMake isn't a build system at all, it
> > does
> > > configuration and produces build files for another
> > tool (like make or an
> > > IDE).  I see no point in maintaining duplicate
> > configuration systems,
> > > and CMake's scripting language is so attrocious that
> > "replacing"
> > > BuildSystem with CMake script would be a disaster.
> >  It's
> > > cross-compilation support is also a bit weak, and
> > there are a pile of
> > > other things that it does poorly (mostly related to
> > pathologically
> > > dysfunctional "Find*.cmake" modules).  That doesn't
> > mean it isn't useful
> > > for producing build files.
> > > Jed
