[petsc-users] configure problems
Thu Jul 22 09:13:33 CDT 2010
On Thu, 22 Jul 2010, Dominik Szczerba wrote:
> Many thanks for your precious feedback.
> My MPICH install is 64 bit but it seems that for some reason 32 bit VC
> compiler is invoked (I have both 32 and 64 installed).
As mentioned - whichever compiler is first in the PATH is used
cl
> I am clarifying with a local MSVC expert how to control this, will update
> you later today.
One way to control this - is to run the desired 'build env' cmd - as
mentioned in the installation instructions.
http://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html#Windows
Satish
> Dominik
> On Thu, Jul 22, 2010 at 3:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> > > Files/MPICH2/lib/amd64/msmpi.lib
> > Looks like - if win32fe doesn't find the file - it doesn't try to
> > convert the path. This is not the cause of his configure failure.
> > The primary issue is: [which is much ahead in configure.log]
> > sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl
> >  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\
> > Files/MPICH2/lib/mpi.lib Ws2_32.lib
> > Executing:
> > /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl  -o
> > sh: conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
> > referenced in function _main^M
> > C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error LNK1120:
> > 1 unresolved externals^M
> > Here cl is finding the correct library - but not MPI_Init symbol in it.
> > For whatever reason - libmpi.lib is not compatible.
> > Satish
> > On Thu, 22 Jul 2010, Farshid Mossaiby wrote:
> > > I doubt 'cl' can interpret Cygwin paths:
> > > cl : Command line warning D9002 : ignoring unknown option
> > > '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> > > Shouldn't win32fe convert this path first?
> > > Hope this helps.
> > > --- On Wed, 7/21/10, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> > > > From: Dominik Szczerba <dominik at itis.ethz.ch>
> > > > Subject: Re: [petsc-users] configure problems
> > > > To: "PETSc users list" <petsc-users at mcs.anl.gov>
> > > > Date: Wednesday, July 21, 2010, 7:01 PM
> > > > Coming back to the original problem:
> > > > I tried to compile MPICH2 myself
> > > > and failed because of wrong version of automake in Cygwin.
> > > > I then
> > > > installed the Windows binary available on the mpich2
> > > > webpage. I
> > > > configure petsc with:
> > > > $ ./config/configure.py PETSC_DIR=$PWD
> > > > PETSC_ARCH=win64-msvc-release
> > > > --download-c-blas-lapack=1
> > > > --with-mpi-dir='/cygdrive/c/Program
> > > > Files/MPICH2' --with-x=0 --with-debugging=0
> > > > --with-cc='win32fe cl'
> > > > --with-fc=0
> > > > to hear at the end (of a very long configuration
> > > > process...):
> > > > sh:
> > > > cl  -o conftest.exe    -MT -wd4996
> > > > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > > > Executing:
> > > > _MPI_Init
> > > > error
> > > > LNK1120: 1 unresolved externals
> > > > Any directions why would the configuration look for a
> > > > nonexistent
> > > > library? The contents of the installation folder are:
> > > > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > > > total 808
> > > > drwx------+ 1 SYSTEM SYSTEM   4096
> > > > 2010-07-21 15:54 .
> > > > 2010-07-21 15:54 ..
> > > > -rwx------+ 1 SYSTEM SYSTEM   4644
> > > > 2010-02-22 17:13 TraceInput.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09
> > > > cxx.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11
> > > > fmpich2.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13
> > > > fmpich2g.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM   1936
> > > > 2010-02-22 17:13 irlog2rlog.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30
> > > > mpe.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29
> > > > mpi.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30
> > > > rlog.lib
> > > > Best regards,
> > > > Dominik
> > > > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org>
> > > > wrote:
> > > > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley
> > > > <knepley at gmail.com>
> > > > wrote:
> > > > >> This would do you absolutely no good. Even Jed's
> > > > thing needs all the
> > > > >> information that the configure provides. CMake is
> > > > exactly what it
> > > > >> says, make. It does no configuration
> > > > > This isn't true, CMake isn't a build system at all, it
> > > > does
> > > > > configuration and produces build files for another
> > > > tool (like make or an
> > > > > IDE).  I see no point in maintaining duplicate
> > > > configuration systems,
> > > > > and CMake's scripting language is so attrocious that
> > > > "replacing"
> > > > > BuildSystem with CMake script would be a disaster.
> > > >  It's
> > > > > cross-compilation support is also a bit weak, and
> > > > there are a pile of
> > > > > other things that it does poorly (mostly related to
> > > > pathologically
> > > > > dysfunctional "Find*.cmake" modules).  That doesn't
> > > > mean it isn't useful
> > > > > for producing build files.
> > > > > Jed
