[petsc-users] configure problems
Wed Jul 21 11:09:00 CDT 2010
Try:
./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release --download-c-blas-lapack=1 --with-x=0 --with-debugging=0 --with-cc='win32fe cl' --with-fc=0
If it fails - send us configure.log at petsc-maint at mcs.anl.gov
BTW: What do you have in your LIB env variable? [MS search this path for libraries by default]
echo $LIB
Satish
On Wed, 21 Jul 2010, Dominik Szczerba wrote:
> Coming back to the original problem: I tried to compile MPICH2 myself
> and failed because of wrong version of automake in Cygwin. I then
> installed the Windows binary available on the mpich2 webpage. I
> configure petsc with:
> $ ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> --download-c-blas-lapack=1 --with-mpi-dir='/cygdrive/c/Program
> Files/MPICH2' --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> --with-fc=0
> to hear at the end (of a very long configuration process...):
> sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
> cl  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\
> Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> Executing: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
> sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> cl : Command line warning D9002 : ignoring unknown option
> '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
> referenced in function _main
> C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error
> LNK1120: 1 unresolved externals
> Any directions why would the configuration look for a nonexistent
> library? The contents of the installation folder are:
> $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> total 808
> drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 .
> drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 ..
> -rwx------+ 1 SYSTEM SYSTEM   4644 2010-02-22 17:13 TraceInput.lib
> -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09 cxx.lib
> -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11 fmpich2.lib
> -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13 fmpich2g.lib
> -rwx------+ 1 SYSTEM SYSTEM   1936 2010-02-22 17:13 irlog2rlog.lib
> -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30 mpe.lib
> -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29 mpi.lib
> -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30 rlog.lib
> Best regards,
> Dominik
> On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org> wrote:
> > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley <knepley at gmail.com> wrote:
> >> This would do you absolutely no good. Even Jed's thing needs all the
> >> information that the configure provides. CMake is exactly what it
> >> says, make. It does no configuration
> > This isn't true, CMake isn't a build system at all, it does
> > configuration and produces build files for another tool (like make or an
> > IDE).  I see no point in maintaining duplicate configuration systems,
> > and CMake's scripting language is so attrocious that "replacing"
> > BuildSystem with CMake script would be a disaster.  It's
> > cross-compilation support is also a bit weak, and there are a pile of
> > other things that it does poorly (mostly related to pathologically
> > dysfunctional "Find*.cmake" modules).  That doesn't mean it isn't useful
> > for producing build files.
> > Jed
