[petsc-users] configure problems
Dominik Szczerba
dominik at itis.ethz.ch
Wed Jul 21 09:31:13 CDT 2010
Coming back to the original problem: I tried to compile MPICH2 myself
and failed because of wrong version of automake in Cygwin. I then
installed the Windows binary available on the mpich2 webpage. I
configure petsc with:
$ ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
--download-c-blas-lapack=1 --with-mpi-dir='/cygdrive/c/Program
Files/MPICH2' --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
--with-fc=0
to hear at the end (of a very long configuration process...):
sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
cl -o conftest.exe -MT -wd4996 conftest.o /cygdrive/c/Program\
Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
Executing: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
cl : Command line warning D9002 : ignoring unknown option
'/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
referenced in function _main
C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error
LNK1120: 1 unresolved externals
Any directions why would the configuration look for a nonexistent
library? The contents of the installation folder are:
$ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
total 808
drwx------+ 1 SYSTEM SYSTEM 4096 2010-07-21 15:54 .
drwx------+ 1 SYSTEM SYSTEM 4096 2010-07-21 15:54 ..
-rwx------+ 1 SYSTEM SYSTEM 4644 2010-02-22 17:13 TraceInput.lib
-rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09 cxx.lib
-rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11 fmpich2.lib
-rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13 fmpich2g.lib
-rwx------+ 1 SYSTEM SYSTEM 1936 2010-02-22 17:13 irlog2rlog.lib
-rwx------+ 1 SYSTEM SYSTEM 10430 2010-02-22 16:30 mpe.lib
-rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29 mpi.lib
-rwx------+ 1 SYSTEM SYSTEM 61286 2010-02-22 16:30 rlog.lib
Best regards,
Dominik
On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley <knepley at gmail.com> wrote:
>> This would do you absolutely no good. Even Jed's thing needs all the
>> information that the configure provides. CMake is exactly what it
>> says, make. It does no configuration
> This isn't true, CMake isn't a build system at all, it does
> configuration and produces build files for another tool (like make or an
> IDE). I see no point in maintaining duplicate configuration systems,
> and CMake's scripting language is so attrocious that "replacing"
> BuildSystem with CMake script would be a disaster. It's
> cross-compilation support is also a bit weak, and there are a pile of
> other things that it does poorly (mostly related to pathologically
> dysfunctional "Find*.cmake" modules). That doesn't mean it isn't useful
> for producing build files.
> Jed
