[petsc-users] configure problems
    Dominik Szczerba
    dominik at itis.ethz.ch
    Wed Jul 21 16:08:30 CDT 2010
I assume you mean in addition --with-mpi=0, else I am expecting an error
message.
Configure did not bring up any errors:
Compilers:
  C Compiler:
/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl  -MT
-wd4996
Linkers:
  Static linker:   /usr/bin/ar cr
BLAS/LAPACK:
-L/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/win64-msvc-release/lib
-lf2clapack -L/cygdrive/c/Users/Dominik/P
-lf2cblas
PETSc:
  PETSC_ARCH: win64-msvc-release
  PETSC_DIR: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3
  Clanguage: C
  Scalar type: real
  Precision: double
  Memory alignment: 16
  shared libraries: disabled
  dynamic libraries: disabled
xxx=========================================================================xxx
   Configure stage complete. Now build PETSc libraries with:
   make PETSC_DIR=/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3
PETSC_ARCH=win64-msvc-release all
Building was also successful. Test run OK (with 1 MPI process)
My LIB:
C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\ATLMFC\LIB;C:\Program
Files (x86)\Microsoft Visual Studio 9.0\VC\LIB;C:\Program Files\Microsoft
SDKs\Windows\v6.0A\lib;
Many thanks for any hints how to get a usable MPICH2 installation,
Dominik
On Wed, Jul 21, 2010 at 6:09 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Try:
> ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> --download-c-blas-lapack=1 --with-x=0 --with-debugging=0 --with-cc='win32fe
> cl' --with-fc=0
> If it fails - send us configure.log at petsc-maint at mcs.anl.gov
> BTW: What do you have in your LIB env variable? [MS search this path for
> libraries by default]
> echo $LIB
> Satish
> On Wed, 21 Jul 2010, Dominik Szczerba wrote:
> > Coming back to the original problem: I tried to compile MPICH2 myself
> > and failed because of wrong version of automake in Cygwin. I then
> > installed the Windows binary available on the mpich2 webpage. I
> > configure petsc with:
> > $ ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> > --download-c-blas-lapack=1 --with-mpi-dir='/cygdrive/c/Program
> > Files/MPICH2' --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> > --with-fc=0
> > to hear at the end (of a very long configuration process...):
> > sh: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
> > cl  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\
> > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > Executing:
> > sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> > cl : Command line warning D9002 : ignoring unknown option
> > '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> > conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
> > referenced in function _main
> > C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error
> > LNK1120: 1 unresolved externals
> > Any directions why would the configuration look for a nonexistent
> > library? The contents of the installation folder are:
> > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > total 808
> > drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 .
> > drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 ..
> > -rwx------+ 1 SYSTEM SYSTEM   4644 2010-02-22 17:13 TraceInput.lib
> > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09 cxx.lib
> > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11 fmpich2.lib
> > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13 fmpich2g.lib
> > -rwx------+ 1 SYSTEM SYSTEM   1936 2010-02-22 17:13 irlog2rlog.lib
> > -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30 mpe.lib
> > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29 mpi.lib
> > -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30 rlog.lib
> > Best regards,
> > Dominik
> > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org> wrote:
> > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley <knepley at gmail.com>
> wrote:
> > >> This would do you absolutely no good. Even Jed's thing needs all the
> > >> information that the configure provides. CMake is exactly what it
> > >> says, make. It does no configuration
> > > This isn't true, CMake isn't a build system at all, it does
> > > configuration and produces build files for another tool (like make or
> an
> > > IDE).  I see no point in maintaining duplicate configuration systems,
> > > and CMake's scripting language is so attrocious that "replacing"
> > > BuildSystem with CMake script would be a disaster.  It's
> > > cross-compilation support is also a bit weak, and there are a pile of
> > > other things that it does poorly (mostly related to pathologically
> > > dysfunctional "Find*.cmake" modules).  That doesn't mean it isn't
> useful
> > > for producing build files.
> > > Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100721/94dfcec1/attachment.htm>
