[petsc-users] help about my ts program
Xuan YU
xxy113 at psu.edu
Fri Jul 2 13:44:25 CDT 2010
On Jul 2, 2010, at 2:21 PM, Jed Brown wrote:
> On Fri, 2 Jul 2010 14:08:14 -0400, Xuan YU <xxy113 at psu.edu> wrote:
>> If I don't provide Jacobian, it will be: type: euler
>> total number of nonlinear solver
>> iterations=0
>> total number of linear solver iterations=0
> The default TS is the simplest possible integrator, forward Euler. Of
> course this doesn't do any solves (no SNES) and is not appropriate for
> stiff systems. Run with -ts_type theta for something more likely to
> work (and which will use SNES).
>> [0]PETSC ERROR: Floating point exception!
>> [0]PETSC ERROR: User provided compute function generated a Not-a-
>> Number!
> Euler is unstable for your problem, this should have nothing to do
> with
> the way you specified the Jacobian.
I tried beuler and pseudo, and I got the errors:
>> Number!
[0]PETSC ERROR: User provided function() line 216 in /work/
petsc/pihm.c(which is ierr = TSStep(ts,&its,&ftime);CHKERRQ(ierr);)
> Jed
Xuan YU
xxy113 at psu.edu
