[petsc-users] help about my ts program
Jed Brown
jed at 59A2.org
Fri Jul 2 13:21:42 CDT 2010
On Fri, 2 Jul 2010 14:08:14 -0400, Xuan YU <xxy113 at psu.edu> wrote:
> If I don't provide Jacobian, it will be: type: euler
> total number of nonlinear solver iterations=0
> total number of linear solver iterations=0
The default TS is the simplest possible integrator, forward Euler. Of
course this doesn't do any solves (no SNES) and is not appropriate for
stiff systems. Run with -ts_type theta for something more likely to
work (and which will use SNES).
> [0]PETSC ERROR: Floating point exception!
> [0]PETSC ERROR: User provided compute function generated a Not-a-Number!
Euler is unstable for your problem, this should have nothing to do with
the way you specified the Jacobian.
Jed
