[petsc-users] help about my ts program
Jed Brown
jed at 59A2.org
Fri Jul 2 18:57:12 CDT 2010
On Fri, 2 Jul 2010 14:44:25 -0400, Xuan YU <xxy113 at psu.edu> wrote:
> On Jul 2, 2010, at 2:21 PM, Jed Brown wrote:
> > On Fri, 2 Jul 2010 14:08:14 -0400, Xuan YU <xxy113 at psu.edu> wrote:
> >> If I don't provide Jacobian, it will be: type: euler
> >> total number of nonlinear solver
> >> iterations=0
> >> total number of linear solver iterations=0
> > The default TS is the simplest possible integrator, forward Euler. Of
> > course this doesn't do any solves (no SNES) and is not appropriate for
> > stiff systems. Run with -ts_type theta for something more likely to
> > work (and which will use SNES).
> >> [0]PETSC ERROR: Floating point exception!
> >> [0]PETSC ERROR: User provided compute function generated a Not-a-
> >> Number!
> > Euler is unstable for your problem, this should have nothing to do
> > with
> > the way you specified the Jacobian.
> I tried beuler and pseudo, and I got the errors:
If you have petsc-dev, run in a debugger with -fp_trap to see where the
NaN is first computed. Some possibilities include domain error (like
negative density), nonlinear instability, and inadequate solution of the
linear system.
Jed
