[petsc-users] Errors while install pets-dev
Mon Jan 25 23:22:49 CST 2010
Ok. My guess is - 0.9.5 is a bit too old - and perhaps newer versions
might work automatically with the 'system proxy' settings.
The proxy url 'http://:8080/' looks non-standard [Doesn't list a
machine] - so that might be something mercurial proxy is unable to
handle.
Satish
On Tue, 26 Jan 2010, (Rebecca) Xuefei YUAN wrote:
> I do not know why the connection time is out, but for completeness, I am using
> Ubuntu 8.04, and the mercurial version is Mercurial Distributed SCM (version
> 0.9.5).
> Cheers,
> Rebecca
> Quoting Satish Balay <balay at mcs.anl.gov>:
> > Gald it works now.
> > BTW: What OS/version do you have? And what version of mercurial is
> > this? [just for completeness]
> > Satish
> > On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
> > > Dear Satish,
> > > There is no such an error showed up this time.
> > > Thanks very much!
> > > Rebecca
> > > > > Dear Satish,
> > > > > I got these from those two commands:
> > > > > rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i proxy
> > > > > http_proxy=http://:8080/
> > > > > no_proxy=localhost,127.0.0.0/8,*.local
> > > > > rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i http
> > > > > And my System -> Preferences -> Network Proxy shows three options:
> > > > > * Direct internet connection
> > > > > * Manual proxy configuration
> > > > > * Automatic proxy configuration
> > > > > I think it is the third one with "Autoconfiguration URL" blank.
> > > > > Does this mean my .hgrc file should have two lines of
> > > > > [http_proxy]
> > > > > host=http://:8080/
> > > > Give it a try and see if it works. I'm not sure how all this proxy
> > > > stuff works though..
> > > > Satish
