[petsc-users] Errors while install pets-dev
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Mon Jan 25 23:12:34 CST 2010
I do not know why the connection time is out, but for completeness, I
am using Ubuntu 8.04, and the mercurial version is Mercurial
Distributed SCM (version 0.9.5).
Cheers,
Rebecca
Quoting Satish Balay <balay at mcs.anl.gov>:
> Gald it works now.
> BTW: What OS/version do you have? And what version of mercurial is
> this? [just for completeness]
> Satish
> On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
>> Dear Satish,
>> There is no such an error showed up this time.
>> Thanks very much!
>> Rebecca
>> > > Dear Satish,
>> > > I got these from those two commands:
>> > > rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i proxy
>> > > http_proxy=http://:8080/
>> > > no_proxy=localhost,127.0.0.0/8,*.local
>> > > rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i http
>> > > And my System -> Preferences -> Network Proxy shows three options:
>> > > * Direct internet connection
>> > > * Manual proxy configuration
>> > > * Automatic proxy configuration
>> > > I think it is the third one with "Autoconfiguration URL" blank.
>> > > Does this mean my .hgrc file should have two lines of
>> > > [http_proxy]
>> > > host=http://:8080/
>> > Give it a try and see if it works. I'm not sure how all this proxy
>> > stuff works though..
>> > Satish
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
