[petsc-users] Errors while install pets-dev
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Mon Jan 25 23:09:29 CST 2010
oops, an error comes up:
rebecca at YuanWork:~/soft$ hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
destination directory: petsc-dev
abort: error: Connection timed out
The problem might still be there.
If I ignore the "make test" error happened to ex5.f, I am able to make
petsc-dev/src/snes/examples/tutorials/ex48.c successfully.
Thanks again very much!
Rebecca
Quoting "(Rebecca) Xuefei YUAN" <xy2102 at columbia.edu>:
> Dear Satish,
> There is no such an error showed up this time.
> Thanks very much!
> Rebecca
> Quoting Satish Balay <balay at mcs.anl.gov>:
>> On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
>>> Dear Satish,
>>> I got these from those two commands:
>>> rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i proxy
>>> http_proxy=http://:8080/
>>> no_proxy=localhost,127.0.0.0/8,*.local
>>> rebecca at YuanWork:~/soft/petsc-dev$ env |grep -i http
>>> And my System -> Preferences -> Network Proxy shows three options:
>>> * Direct internet connection
>>> * Manual proxy configuration
>>> * Automatic proxy configuration
>>> I think it is the third one with "Autoconfiguration URL" blank.
>>> Does this mean my .hgrc file should have two lines of
>>> [http_proxy]
>>> host=http://:8080/
>> Give it a try and see if it works. I'm not sure how all this proxy
>> stuff works though..
>> Satish
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
Columbia University
Tel:917-399-8032
