[petsc-users] Errors while install pets-dev
Mon Jan 25 22:32:19 CST 2010
On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
> Dear Satish,
> I tried to find ~/.hgrc file but there is none. Instead, I found a global hgrc
> file located at
> /etc/mercurial/hgrc
> and its content is one sentence of comments:
> # system-wide mercurial configuration file
> # See hgrc(5) for more information
> Shall I create a new .hgrc file as indicated in url:
> http://www.selenic.com/pipermail/mercurial/2006-June/008690.html
Yes - ~/.hgrc is created by the user. You can just have the 2 lines
needed for proxy.
>  I tried to find my proxy host name and port, and in Firefox, it is
> said "Use system proxy settings" under "Connection Settings" tab
> under "Preferences" in Firefox, if this is the case, what is my real
> proxh host name and port?
For sure firefox must be using http_proxy [otherwise it would be set
to 'no proxy'. But I'm not sure how you can find the settings. What
do you have for
env |grep -i proxy
env |grep -i http
Also what OS is this? If you are using gnome - there can be proxy
settings there. On my Fedora 12 box with Gnome - the settings can be
at:
'System -> Preferences -> Network Proxy'
Satish
> Is
> [http_proxy]
> host=proxy:8080
> a default one?
> Thanks very much!
> Rebecca
> Quoting Satish Balay <balay at mcs.anl.gov>:
> > Sorry - forgot to mention the url
> > http://mail.openjdk.java.net/pipermail/build-dev/2007-December/000628.html
> > Satish
> > On Mon, 25 Jan 2010, Satish Balay wrote:
> > > Do you have to use proxy for your http connections? If so - perhaps
> > > you can try adding the settings to ~/.hgrc - as this url indicates and
> > > see if it fixes the problem.
> > > Satish
> > > > Hi,All,
> > > > I try to install a pets-dev locally according to the instruction
> > > > http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
> > > > I have installed mercurial, but when I get the second step, I get  some
> > > > error
> > > > like:
> > > > rebecca at YuanWork:~/soft$ hg clone
> > > > http://petsc.cs.iit.edu/petsc/petsc-dev
> > > > destination directory: petsc-dev
> > > > abort: error: Name or service not known
> > > > Is there anything wrong?
> > > > Thanks!
