[petsc-users] Errors while install pets-dev
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Mon Jan 25 22:20:59 CST 2010
Dear Satish,
I tried to find ~/.hgrc file but there is none. Instead, I found a
global hgrc file located at
/etc/mercurial/hgrc
and its content is one sentence of comments:
# system-wide mercurial configuration file
# See hgrc(5) for more information
Shall I create a new .hgrc file as indicated in url:
http://www.selenic.com/pipermail/mercurial/2006-June/008690.html
I tried to find my proxy host name and port, and in Firefox, it is said
"Use system proxy settings" under "Connection Settings" tab under
"Preferences" in Firefox, if this is the case, what is my real proxh
host name and port? Is
[http_proxy]
host=proxy:8080
a default one?
Thanks very much!
Rebecca
Quoting Satish Balay <balay at mcs.anl.gov>:
> Sorry - forgot to mention the url
> http://mail.openjdk.java.net/pipermail/build-dev/2007-December/000628.html
> Satish
> On Mon, 25 Jan 2010, Satish Balay wrote:
>> Do you have to use proxy for your http connections? If so - perhaps
>> you can try adding the settings to ~/.hgrc - as this url indicates and
>> see if it fixes the problem.
>> Satish
>> On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
>> > Hi,All,
>> > I try to install a pets-dev locally according to the instruction
>> > http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
>> > I have installed mercurial, but when I get the second step, I get
>>  some error
>> > like:
>> > rebecca at YuanWork:~/soft$ hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
>> > destination directory: petsc-dev
>> > abort: error: Name or service not known
>> > Is there anything wrong?
>> > Thanks!
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
