[petsc-users] x64 build problem
Rob Ellis Robert.G.Ellis at Shaw.ca
Sun Jan 17 19:15:13 CST 2010
Hi Matt,
Of course, my apologies, here it is.
Rob
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Sunday, January 17, 2010 5:10 PM
To: PETSc users list
Subject: Re: [petsc-users] x64 build problem
You have to send configure.log (send it to petsc-maint at mcs.anl.gov) or we
have absolutely
no idea what is going on.
  Matt
On Sun, Jan 17, 2010 at 7:07 PM, Rob Ellis <Robert.G.Ellis at shaw.ca> wrote:
Hi Petsc Experts
I've been running Petsc/TAO successfully under CVF VC but need to move to 64
bit. Now, I'm trying to compile Petsc on a Windows XP64, VS2008 C/C++ and
IVF 11 from the IVF compiler shell with Cygwin bash using the command
./config/configure.py                  \
     --with-cc='win32fe cl'             \
     --with-cxx='win32fe cl'           \
     --with-fc=ifort                            \
     --with-mpi-dir=/cygdrive/c/MPICH2 \
     --download-f-blas-lapack=1        \
     --with-clanguage=C++ CXXFLAGS='-DMPICH_SKIP_MPICXX -MT -GR -EHsc'
and get the following error:
             Configuring PETSc to compile on your system
TESTING: checkCCompiler from
config.setCompilers(/cygdrive/z/ai/petsc-3.0.0-p9/config/BuildSystem/config/
setCompilers.py:394)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C compiler you provided with -with-cc=win32fe cl does not work
However if I type cl at the command line, cl seems to work
$ cl
Microsoft (R) C/C++ Optimizing Compiler Version 15.00.21022.08 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
Any help would be most appreciated.
Cheers,
Rob
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100117/b659aa35/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100117/b659aa35/attachment-0001.obj>
