[petsc-users] x64 build problem
Matthew Knepley
knepley at gmail.com
Sun Jan 17 19:10:15 CST 2010
You have to send configure.log (send it to petsc-maint at mcs.anl.gov) or we
have absolutely
no idea what is going on.
Matt
On Sun, Jan 17, 2010 at 7:07 PM, Rob Ellis <Robert.G.Ellis at shaw.ca> wrote:
> Hi Petsc Experts
> I've been running Petsc/TAO successfully under CVF VC but need to move to
> 64 bit. Now, I'm trying to compile Petsc on a Windows XP64, VS2008 C/C++ and
> IVF 11 from the IVF compiler shell with Cygwin bash using the command
> ./config/configure.py \
> --with-cc='win32fe cl' \
> --with-cxx='win32fe cl' \
> --with-fc=ifort \
> --with-mpi-dir=/cygdrive/c/MPICH2 \
> --download-f-blas-lapack=1 \
> --with-clanguage=C++ CXXFLAGS='-DMPICH_SKIP_MPICXX -MT -GR -EHsc'
> and get the following error:
> Configuring PETSc to compile on your system
> TESTING: checkCCompiler from
> config.setCompilers(/cygdrive/z/ai/petsc-3.0.0-p9/config/BuildSystem/config/setCompilers.py:394)
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> C compiler you provided with -with-cc=win32fe cl does not work
> However if I type cl at the command line, cl seems to work
> $ cl
> Microsoft (R) C/C++ Optimizing Compiler Version 15.00.21022.08 for x64
> Copyright (C) Microsoft Corporation. All rights reserved.
> usage: cl [ option... ] filename... [ /link linkoption... ]
> Any help would be most appreciated.
> Cheers,
> Rob
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100117/adb46af7/attachment.htm>
