[petsc-users] x64 build problem
Rob Ellis Robert.G.Ellis at Shaw.ca
Sun Jan 17 19:07:35 CST 2010
Hi Petsc Experts
I've been running Petsc/TAO successfully under CVF VC but need to move to 64
bit. Now, I'm trying to compile Petsc on a Windows XP64, VS2008 C/C++ and
IVF 11 from the IVF compiler shell with Cygwin bash using the command
./config/configure.py                  \
     --with-cc='win32fe cl'             \
     --with-cxx='win32fe cl'           \
     --with-fc=ifort                            \
     --with-mpi-dir=/cygdrive/c/MPICH2 \
     --download-f-blas-lapack=1        \
     --with-clanguage=C++ CXXFLAGS='-DMPICH_SKIP_MPICXX -MT -GR -EHsc'
and get the following error:
             Configuring PETSc to compile on your system
TESTING: checkCCompiler from
config.setCompilers(/cygdrive/z/ai/petsc-3.0.0-p9/config/BuildSystem/config/
setCompilers.py:394)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C compiler you provided with -with-cc=win32fe cl does not work
However if I type cl at the command line, cl seems to work
$ cl
Microsoft (R) C/C++ Optimizing Compiler Version 15.00.21022.08 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
Any help would be most appreciated.
Cheers,
Rob
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100117/65101131/attachment.htm>
