[petsc-users] command line option for superlu_dist
Tue Jan 5 12:51:27 CST 2010
   Likely SuperLU_Dist is failing on the provided matrix. Could you
use -ksp_view_binary on the run and copy the resulting file
binaryoutput to the anonymous ftp site ftp.mcs.anl.gov in the
directory incoming and tell us when the matrix is there.  Sparse
parallel factorizations are a bit fragile and can fail.
     Barry
On Jan 5, 2010, at 12:01 PM, hxie at umn.edu wrote:
> The information for superlu_dist
> Linear solve converged due to CONVERGED_ITS iterations 1
> KSP Object:
> type: preonly
> maximum iterations=1000, initial guess is zero
> tolerances:  relative=1e-06, absolute=1e-10, divergence=100
> left preconditioning
> PC Object:
> type: lu
>   LU: out-of-place factorization
>     matrix ordering: natural
>   LU: tolerance for zero pivot 1e-12
>   LU: factor fill ratio needed 0
>        Factored matrix follows
>       Matrix Object:
>         type=mpiaij, rows=291896, cols=291896
>         package used to perform factorization: superlu_dist
>         total: nonzeros=0, allocated nonzeros=583792
>           SuperLU_DIST run parameters:
>             Process grid nprow 2 x npcol 2              Equilibrate
> matrix TRUE              Matrix input mode 1              Replace
> tiny pivots TRUE              Use iterative refinement
> FALSE              Processors in row 2 col partition 2
> Row permutation LargeDiag              Column permutation
> MMD_AT_PLUS_A
>             Parallel symbolic factorization FALSE
> Repeated factorization SamePattern
> linear system matrix followed by preconditioner matrix:
> Matrix Object:
>   total: nonzeros=33670280, allocated nonzeros=36641300
>     using I-node (on process 0) routines: found 21607 nodes, limit
> used is 5
> Matrix Object:
> used is 5
> WARNING:  Tolerance not met by convergence norms
> Solution norm =          NaN
> Total CPU time   =   39.0 min
> For mumps, it takes only 2min to get some result "Solution norm =
> 0.255E+03".
