[petsc-users] command line option for superlu_dist
Tue Jan 5 12:13:45 CST 2010
1) The solution norm you report is NaN, which indicates memory corruption in
your code
2) The number of allocated nonzeros is really suspicious. There are only 2
nonzeros per row?
  Matt
On Tue, Jan 5, 2010 at 12:01 PM, <hxie at umn.edu> wrote:
> The information for superlu_dist
> Linear solve converged due to CONVERGED_ITS iterations 1
> KSP Object:
>  type: preonly
>  maximum iterations=1000, initial guess is zero
>  tolerances:  relative=1e-06, absolute=1e-10, divergence=100
>  left preconditioning
> PC Object:
>  type: lu
>   LU: out-of-place factorization
>     matrix ordering: natural
>   LU: tolerance for zero pivot 1e-12
>   LU: factor fill ratio needed 0
>        Factored matrix follows
>       Matrix Object:
>         type=mpiaij, rows=291896, cols=291896
>         package used to perform factorization: superlu_dist
>         total: nonzeros=0, allocated nonzeros=583792
>           SuperLU_DIST run parameters:
>             Process grid nprow 2 x npcol 2             Equilibrate matrix
> TRUE             Matrix input mode 1             Replace tiny pivots TRUE
>           Use iterative refinement FALSE             Processors in row 2 col
> partition 2             Row permutation LargeDiag             Column
> permutation MMD_AT_PLUS_A
>             Parallel symbolic factorization FALSE             Repeated
> factorization SamePattern
>  linear system matrix followed by preconditioner matrix:
>  Matrix Object:
>   total: nonzeros=33670280, allocated nonzeros=36641300
>     using I-node (on process 0) routines: found 21607 nodes, limit used is
> 5
>  Matrix Object:
> 5
> WARNING:  Tolerance not met by convergence norms
> Solution norm =          NaN
> Total CPU time   =   39.0 min
> For mumps, it takes only 2min to get some result "Solution norm =
> 0.255E+03".
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100105/e046d246/attachment.htm>
