[petsc-users] command line option for superlu_dist
hxie at umn.edu hxie at umn.edu
Tue Jan 5 13:00:23 CST 2010
> 1) The solution norm you report is NaN, which indicates memory corruption
> in
your code
I guess the reason may be a division by zero. The diagonals of the matrix
have some zeros.
>2) The number of allocated nonzeros is really suspicious. There are only 2
nonzeros per row?
At least 5.
Hui
