[petsc-users] run direct linear solver in parallel
Mon Dec 13 08:34:56 CST 2010
   The problem is not in PETSc.    Run in the debugger  and see exactly where this memcpy() overlap happens and if it can be fixed.
  Barry
On Dec 13, 2010, at 4:30 AM, Max Ng wrote:
> Hi,
> I am having a similar problem and I'm using PETSc 3.1-p6. I wish to use SPOOLES because I need to build on Windows with VC++ (and without a Fortran compiler). And in my tests somehow SPOOLES performs better than SuperLU.
> My program runs correctly in mpiexec -n 1. When I try mpiexec -n 2, I got this error:
> Assertion failed in file helper_fns.c at line 337: 0
> memcpy argument memory ranges overlap, dst_=0x972ef84 src_=0x972ef84 len_=4
> internal ABORT - process 1
> memcpy argument memory ranges overlap, dst_=0x90c4018 src_=0x90c4018 len_=4
> internal ABORT - process 0
> rank 1 in job 113  vm1_57881   caused collective abort of all ranks
>   exit status of rank 1: killed by signal 9
> Here is the source code:
>             // N = 40000, n = 20000, nnz = 9
>             MatCreate(comm, &mat);
>             MatSetType(mat, MATAIJ);
>             MatSetSizes(mat, n, n, N, N);
>             MatSeqAIJSetPreallocation(mat, nnz, PETSC_NULL);
>             MatMPIAIJSetPreallocation(mat, nnz, PETSC_NULL, nnz, PETSC_NULL);
>             // some code to fill the matrix values
>             KSPCreate(comm, &ksp);
>             KSPSetOperators(ksp, mat, mat, DIFFERENT_NONZERO_PATTERN);
>             KSPSetType(ksp, KSPPREONLY);
>             KSPGetPC(ksp, &pc);
>             PCSetType(pc, PCLU);
>             PCFactorSetMatSolverPackage(pc, MAT_SOLVER_SPOOLES);
>             KSPSetUp(ksp);
> It crashes at the KSPSetUp() statement.
> Do you have any ideas? Thanks in advance!
> Max Ng
> On Dec 3, 2010, at 4:19 PM, Xiangdong Liang wrote:
>> > Hi everyone,
>> > I am wondering how I can run the direct solver in parallel. I can run
>> > my program in a single processor with direct linear solver by
>> > ./foo.out  -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package spooles
>> > However, when I try to run it with mpi:
>> > mpirun.openmpi -np 2 ./foo.out -ksp_type preonly -pc_type lu
>> > I got error like this:
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: No support for this operation for this object type!
>> > [0]PETSC ERROR: Matrix type mpiaij  symbolic LU!
>> > [0]PETSC ERROR: Libraries linked from
>> > /home/hazelsct/petsc-2.3.3/lib/linux-gnu-c-opt
>> > [0]PETSC ERROR: Configure run at Mon Jun 30 14:37:52 2008
>> > [0]PETSC ERROR: Configure options --with-shared --with-dynamic
>> > --with-debugging=0 --useThreads 0 --with-mpi-dir=/usr/lib/openmpi
>> > --with-mpi-shared=1 --with-blas-lib=-lblas --with-lapack-lib=-llapack
>> > --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse
>> > --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"
>> > --with-superlu=1 --with-superlu-include=/usr/include/superlu
>> > --with-superlu-lib=/usr/lib/libsuperlu.so --with-spooles=1
>> > --with-spooles-include=/usr/include/spooles
>> > --with-spooles-lib=/usr/lib/libspooles.so --with-hypre=1
>> > --with-hypre-dir=/usr --with-babel=1 --with-babel-dir=/usr
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: MatLUFactorSymbolic() line 2174 in src/mat/interface/matrix.c
>> > [0]PETSC ERROR: PCSetUp_LU() line 257 in src/ksp/pc/impls/factor/lu/lu.c
>> > Would you like to tell me where I am doing wrong? I appreciate your help.
>> > Xiangdong
