[petsc-users] run direct linear solver in parallel
Max Ng maxwindiff at gmail.com
Mon Dec 13 04:30:11 CST 2010
I am having a similar problem and I'm using PETSc 3.1-p6. I wish to use
SPOOLES because I need to build on Windows with VC++ (and without a Fortran
compiler). And in my tests somehow SPOOLES performs better than SuperLU.
My program runs correctly in mpiexec -n 1. When I try mpiexec -n 2, I got
this error:
Assertion failed in file helper_fns.c at line 337: 0
memcpy argument memory ranges overlap, dst_=0x972ef84 src_=0x972ef84 len_=4
internal ABORT - process 1
memcpy argument memory ranges overlap, dst_=0x90c4018 src_=0x90c4018 len_=4
internal ABORT - process 0
rank 1 in job 113  vm1_57881   caused collective abort of all ranks
  exit status of rank 1: killed by signal 9
Here is the source code:
            // N = 40000, n = 20000, nnz = 9
            MatCreate(comm, &mat);
            MatSetType(mat, MATAIJ);
            MatSetSizes(mat, n, n, N, N);
            MatSeqAIJSetPreallocation(mat, nnz, PETSC_NULL);
            MatMPIAIJSetPreallocation(mat, nnz, PETSC_NULL, nnz,
PETSC_NULL);
            // some code to fill the matrix values
            KSPCreate(comm, &ksp);
            KSPSetOperators(ksp, mat, mat, DIFFERENT_NONZERO_PATTERN);
            KSPSetType(ksp, KSPPREONLY);
            KSPGetPC(ksp, &pc);
            PCSetType(pc, PCLU);
            PCFactorSetMatSolverPackage(pc, MAT_SOLVER_SPOOLES);
            KSPSetUp(ksp);
It crashes at the KSPSetUp() statement.
Do you have any ideas? Thanks in advance!
Max Ng
On Dec 3, 2010, at 4:19 PM, Xiangdong Liang wrote:
> Hi everyone,> > I am wondering how I can run the direct solver in parallel. I can run> my program in a single processor with direct linear solver by> > ./foo.out  -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package spooles> > However, when I try to run it with mpi:> > mpirun.openmpi -np 2 ./foo.out -ksp_type preonly -pc_type lu> -pc_factor_mat_solver_package spooles> > I got error like this:> > [0]PETSC ERROR: --------------------- Error Message> ------------------------------------> [0]PETSC ERROR: No support for this operation for this object type!> [0]PETSC ERROR: Matrix type mpiaij  symbolic LU!> > [0]PETSC ERROR: Libraries linked from> /home/hazelsct/petsc-2.3.3/lib/linux-gnu-c-opt> [0]PETSC ERROR: Configure run at Mon Jun 30 14:37:52 2008> [0]PETSC ERROR: Configure options --with-shared --with-dynamic> --with-debugging=0 --useThreads 0 --with-mpi-dir=/usr/lib/openmpi> --with-mpi-shared=1 --with-blas-lib=-lblas --with-lapack-lib=-llapack> --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse> --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"> --with-superlu=1 --with-superlu-include=/usr/include/superlu> --with-superlu-lib=/usr/lib/libsuperlu.so --with-spooles=1> --with-spooles-include=/usr/include/spooles> --with-spooles-lib=/usr/lib/libspooles.so --with-hypre=1> --with-hypre-dir=/usr --with-babel=1 --with-babel-dir=/usr> [0]PETSC ERROR:> ------------------------------------------------------------------------> [0]PETSC ERROR: MatLUFactorSymbolic() line 2174 in src/mat/interface/matrix.c> [0]PETSC ERROR: PCSetUp_LU() line 257 in src/ksp/pc/impls/factor/lu/lu.c> -------------------------------------------------------> > Would you like to tell me where I am doing wrong? I appreciate your help.> > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101213/4299767d/attachment-0001.htm>
