[petsc-users] run direct linear solver in parallel
Hong Zhang
hzhang at mcs.anl.gov
Mon Dec 13 09:00:51 CST 2010
Max,
Does superlu_dist crash?
Spooles has been out of support from its developers for more than 10 years.
For small testing problems, it can be faster.
Mumps is a good and robust direct solver we usually recommend, but it
requires f90.
Hong
On Mon, Dec 13, 2010 at 8:34 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The problem is not in PETSc. Run in the debugger and see exactly where this memcpy() overlap happens and if it can be fixed.
> Barry
> On Dec 13, 2010, at 4:30 AM, Max Ng wrote:
>> Hi,
>> I am having a similar problem and I'm using PETSc 3.1-p6. I wish to use SPOOLES because I need to build on Windows with VC++ (and without a Fortran compiler). And in my tests somehow SPOOLES performs better than SuperLU.
>> My program runs correctly in mpiexec -n 1. When I try mpiexec -n 2, I got this error:
>> Assertion failed in file helper_fns.c at line 337: 0
>> memcpy argument memory ranges overlap, dst_=0x972ef84 src_=0x972ef84 len_=4
>> internal ABORT - process 1
>> memcpy argument memory ranges overlap, dst_=0x90c4018 src_=0x90c4018 len_=4
>> internal ABORT - process 0
>> rank 1 in job 113 vm1_57881 caused collective abort of all ranks
>> exit status of rank 1: killed by signal 9
>> Here is the source code:
>> // N = 40000, n = 20000, nnz = 9
>> MatCreate(comm, &mat);
>> MatSetType(mat, MATAIJ);
>> MatSetSizes(mat, n, n, N, N);
>> MatSeqAIJSetPreallocation(mat, nnz, PETSC_NULL);
>> MatMPIAIJSetPreallocation(mat, nnz, PETSC_NULL, nnz, PETSC_NULL);
>> // some code to fill the matrix values
>> KSPCreate(comm, &ksp);
>> KSPSetOperators(ksp, mat, mat, DIFFERENT_NONZERO_PATTERN);
>> KSPSetType(ksp, KSPPREONLY);
>> KSPGetPC(ksp, &pc);
>> PCSetType(pc, PCLU);
>> PCFactorSetMatSolverPackage(pc, MAT_SOLVER_SPOOLES);
>> KSPSetUp(ksp);
>> It crashes at the KSPSetUp() statement.
>> Do you have any ideas? Thanks in advance!
>> Max Ng
>> On Dec 3, 2010, at 4:19 PM, Xiangdong Liang wrote:
>>> > Hi everyone,
>>> > I am wondering how I can run the direct solver in parallel. I can run
>>> > my program in a single processor with direct linear solver by
>>> > ./foo.out -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package spooles
>>> > However, when I try to run it with mpi:
>>> > mpirun.openmpi -np 2 ./foo.out -ksp_type preonly -pc_type lu
>>> > I got error like this:
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: No support for this operation for this object type!
>>> > [0]PETSC ERROR: Matrix type mpiaij symbolic LU!
>>> > [0]PETSC ERROR: Libraries linked from
>>> > /home/hazelsct/petsc-2.3.3/lib/linux-gnu-c-opt
>>> > [0]PETSC ERROR: Configure run at Mon Jun 30 14:37:52 2008
>>> > [0]PETSC ERROR: Configure options --with-shared --with-dynamic
>>> > --with-debugging=0 --useThreads 0 --with-mpi-dir=/usr/lib/openmpi
>>> > --with-mpi-shared=1 --with-blas-lib=-lblas --with-lapack-lib=-llapack
>>> > --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse
>>> > --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"
>>> > --with-superlu=1 --with-superlu-include=/usr/include/superlu
>>> > --with-superlu-lib=/usr/lib/libsuperlu.so --with-spooles=1
>>> > --with-spooles-include=/usr/include/spooles
>>> > --with-spooles-lib=/usr/lib/libspooles.so --with-hypre=1
>>> > --with-hypre-dir=/usr --with-babel=1 --with-babel-dir=/usr
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: MatLUFactorSymbolic() line 2174 in src/mat/interface/matrix.c
>>> > [0]PETSC ERROR: PCSetUp_LU() line 257 in src/ksp/pc/impls/factor/lu/lu.c
>>> > Would you like to tell me where I am doing wrong? I appreciate your help.
>>> > Xiangdong
