[petsc-users] configure failed on MPI and Intel Compiler environment
Matthew Knepley
knepley at gmail.com
Wed Apr 7 05:22:45 CDT 2010
You must send configure.log to petsc-maint at mcs.anl.gov in order for us to
help you.
Matt
On Wed, Apr 7, 2010 at 10:08 AM, Takuya Sekikawa <sekikawa at msi.co.jp> wrote:
> Dear Petsc developpers,
> I tried to configure PETSc (ver 3.0)
> on Linux (64bit), MPI-enabled, Intel Compiler (icc/icpc) environment,
> but it failed.
> ./config/configure.py --with-mpi=1
> --with-mpi-dir=/opt/home/sekikawa/bin-personal/mpich2 \
> --with-x=0 --with-fc=0 --with-debugging=0 --with-blas-lapack-dir=${MKL_DIR}
> Configuring PETSc to compile on your system
> WARNING! Compiling PETSc with no debugging, this should
> only be done for timing and production runs. All
> development should
> be done when configured using --with-debugging=1
> TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasL*********************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> You set a value for --with-blas-lapack-dir=<dir>, but
> /opt/intel/mkl/10.0.010/lib/em64t cannot be used
> MKL_DIR is set to intel mkl library.
> without MPI (--with-mpi=0), this configure succeeded with no problem.
> and MPICH2 is successfully compiled and running with Intel compiler.
> I would very much like for any suggestion.
> Thanks in advance.
> Takuya
> Takuya Sekikawa
> Mathematical Systems, Inc
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100407/0fd8c882/attachment.htm>
