[petsc-users] configure failed on MPI and Intel Compiler environment
Takuya Sekikawa
sekikawa at msi.co.jp
Wed Apr 7 03:08:03 CDT 2010
Dear Petsc developpers,
I tried to configure PETSc (ver 3.0)
on Linux (64bit), MPI-enabled, Intel Compiler (icc/icpc) environment,
but it failed.
./config/configure.py --with-mpi=1 --with-mpi-dir=/opt/home/sekikawa/bin-personal/mpich2 \
--with-x=0 --with-fc=0 --with-debugging=0 --with-blas-lapack-dir=${MKL_DIR}
Configuring PETSc to compile on your system
WARNING! Compiling PETSc with no debugging, this should
only be done for timing and production runs. All development should
be done when configured using --with-debugging=1
TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasL*********************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
You set a value for --with-blas-lapack-dir=<dir>, but /opt/intel/mkl/10.0.010/lib/em64t cannot be used
MKL_DIR is set to intel mkl library.
without MPI (--with-mpi=0), this configure succeeded with no problem.
and MPICH2 is successfully compiled and running with Intel compiler.
I would very much like for any suggestion.
Thanks in advance.
Takuya
Takuya Sekikawa
Mathematical Systems, Inc
