Performance of MatMatSolve
David Fuentes
fuentesdt at gmail.com
Sat Mar 14 16:23:41 CDT 2009
Thanks a lot Hong,
The switch definitely seemed to balance the load during the SuperLU matmatsolve.
Although I'm not completely sure what I'm seeing. Changing the #dof
also seemed to affect the load balance of the Mumps MatMatSolve.
I need to investigate a bit more.
Looking in the profile. The majority of the time is spent in the
MatSolve called by the MatMatSolve.
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
VecCopy 135030 1.0 6.3319e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecWAXPY 30 1.0 1.6069e-04 1.9 4.32e+03 1.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 840
VecScatterBegin 30 1.0 7.6072e-03 1.5 0.00e+00 0.0 4.7e+04 9.0e+02 0.0e+00 0 0 15 0 0 0 0 50 0 0 0
VecScatterEnd 30 1.0 9.1272e-02 6.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMultAdd 30 1.0 3.3028e-01 1.4 3.89e+07 1.7 4.7e+04 9.0e+02 0.0e+00 0 0 15 0 0 0 0 50 0 0 3679
MatSolve 135030 1.0 3.0340e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 78 0 0 0 0 81 0 0 0 0 0
MatLUFactorSym 30 1.0 2.2563e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 30 1.0 2.7990e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 7 0 0 0 0 7 0 0 0 0 0
MatConvert 150 1.0 2.9276e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+02 0 0 0 0 4 0 0 0 0 30 0
MatScale 60 1.0 2.7492e-01 1.9 1.94e+07 1.7 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2210
MatAssemblyBegin 180 1.0 1.1748e+02236.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+02 2 0 0 0 5 2 0 0 0 40 0
MatAssemblyEnd 180 1.0 1.9992e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+02 0 0 0 0 5 0 0 0 0 40 0
MatGetRow 4320 1.7 2.2634e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 30 1.0 4.2578e+02 1.0 1.75e+11 1.7 4.7e+04 4.0e+06 2.4e+02 11 100 15 97 5 11100 50100 40 12841
MatMatSolve 30 1.0 3.0256e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01 77 0 0 0 1 81 0 0 0 10 0
df
On Fri, 13 Mar 2009, Hong Zhang wrote:
> David,
> You may run with option '-log_summary <log_file>' and
> check which function dominates the time.
> I suspect the symbolic factorization, because it is
> implemented sequentially in mumps.
> If this is the case, you may swich to superlu_dist
> which supports parallel symbolic factorization
> in the latest release.
> Let us know what you get,
> Hong
> On Fri, 13 Mar 2009, David Fuentes wrote:
>> The majority of time in my code is spent in the MatMatSolve. I'm running
>> MatMatSolve in parallel using Mumps as the factored matrix.
>> Using top, I've noticed that during the MatMatSolve
>> the majority of the load seems to be on the root process.
>> Is this expected? Or do I most likely have a problem with the matrices that
>> I'm passing in?
>> thank you,
>> David Fuentes
