Performance of MatMatSolve
Hong Zhang
hzhang at mcs.anl.gov
Fri Mar 13 21:10:55 CDT 2009
David,
You may run with option '-log_summary <log_file>' and
check which function dominates the time.
I suspect the symbolic factorization, because it is
implemented sequentially in mumps.
If this is the case, you may swich to superlu_dist
which supports parallel symbolic factorization
in the latest release.
Let us know what you get,
Hong
On Fri, 13 Mar 2009, David Fuentes wrote:
> The majority of time in my code is spent in the MatMatSolve. I'm running
> MatMatSolve in parallel using Mumps as the factored matrix.
> Using top, I've noticed that during the MatMatSolve
> the majority of the load seems to be on the root process.
> Is this expected? Or do I most likely have a problem with the matrices that
> I'm passing in?
> thank you,
> David Fuentes
