Performance of MatMatSolve
Hong Zhang
hzhang at mcs.anl.gov
Sat Mar 14 17:00:18 CDT 2009
David,
Yes, MatMatSolve dominates. Can you also send us the output of
'-log_summary' from superlu_dist?
MUMPS only suppports centralized rhs vector b.
Thus, we must scatter petsc distributed b into a seqential
rhs vector (stored in root proc) in the petsc interface, which
explains why the root proc takes longer time.
I see that the numerical factorization and MatMatSolve are called
30 times.
Do you iterate with the sequence similar to
for i=0,1, ...
B_i = X_(i-1)
Solve A_i * X_i = B_i
i.e., the rhs B is based on previously computed X?
If this is the case, we should take sequential output X (mumps has this
option)
and feed it into next iteration
without mpi scattering.
Hong
On Sat, 14 Mar 2009, David Fuentes wrote:
> Thanks a lot Hong,
> The switch definitely seemed to balance the load during the SuperLU
> matmatsolve.
> Although I'm not completely sure what I'm seeing. Changing the #dof
> also seemed to affect the load balance of the Mumps MatMatSolve.
> I need to investigate a bit more.
> Looking in the profile. The majority of the time is spent in the
> MatSolve called by the MatMatSolve.
> Event Count Time (sec) Flops --- Global --- ---
> Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> VecCopy 135030 1.0 6.3319e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecWAXPY 30 1.0 1.6069e-04 1.9 4.32e+03 1.7 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 840
> VecScatterBegin 30 1.0 7.6072e-03 1.5 0.00e+00 0.0 4.7e+04 9.0e+02
> 0.0e+00 0 0 15 0 0 0 0 50 0 0 0
> VecScatterEnd 30 1.0 9.1272e-02 6.8 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMultAdd 30 1.0 3.3028e-01 1.4 3.89e+07 1.7 4.7e+04 9.0e+02
> 0.0e+00 0 0 15 0 0 0 0 50 0 0 3679
> MatSolve 135030 1.0 3.0340e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 78 0 0 0 0 81 0 0 0 0 0
> MatLUFactorSym 30 1.0 2.2563e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatLUFactorNum 30 1.0 2.7990e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 7 0 0 0 0 7 0 0 0 0 0
> MatConvert 150 1.0 2.9276e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.8e+02 0 0 0 0 4 0 0 0 0 30 0
> MatScale 60 1.0 2.7492e-01 1.9 1.94e+07 1.7 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 2210
> MatAssemblyBegin 180 1.0 1.1748e+02236.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.4e+02 2 0 0 0 5 2 0 0 0 40 0
> MatAssemblyEnd 180 1.0 1.9992e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.4e+02 0 0 0 0 5 0 0 0 0 40 0
> MatGetRow 4320 1.7 2.2634e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatMult 30 1.0 4.2578e+02 1.0 1.75e+11 1.7 4.7e+04 4.0e+06
> 2.4e+02 11 100 15 97 5 11100 50100 40 12841
> MatMatSolve 30 1.0 3.0256e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+01 77 0 0 0 1 81 0 0 0 10 0
> df
> On Fri, 13 Mar 2009, Hong Zhang wrote:
>> David,
>> You may run with option '-log_summary <log_file>' and
>> check which function dominates the time.
>> I suspect the symbolic factorization, because it is
>> implemented sequentially in mumps.
>> If this is the case, you may swich to superlu_dist
>> which supports parallel symbolic factorization
>> in the latest release.
>> Let us know what you get,
>> Hong
>> On Fri, 13 Mar 2009, David Fuentes wrote:
>>> The majority of time in my code is spent in the MatMatSolve. I'm running
>>> MatMatSolve in parallel using Mumps as the factored matrix.
>>> Using top, I've noticed that during the MatMatSolve
>>> the majority of the load seems to be on the root process.
>>> Is this expected? Or do I most likely have a problem with the matrices
>>> that I'm passing in?
>>> thank you,
>>> David Fuentes
