intel compilers and ml fails
Matthew Knepley
knepley at gmail.com
Tue Mar 3 08:17:39 CST 2009
On Tue, Mar 3, 2009 at 7:50 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Hello,
> I'm trying to build petsc-3.0.0-p3 using the intel compilers and math
> kernel on a linux pc. Everything's fine as long as I don't use ml. When I do
> use ml, I get an "Error running configure on ML". The ml configure scripts
> says "configure: error: linking to Fortran libraries from C fails".
> This is my configure command:
> $ config/configure.py --with-cxx=icpc --with-cc=icc --with-fc=ifort
> --with-blas-lapack-dir=/opt/intel/mkl/10.1.1.019 --download-ml=1
> --download-mpich=1
> There's no problem when using gcc and gfortran. The intel compilers and mkl
> are version 10.1. Any ideas on how to fix this problem?
I can't tell anything without configure.log. Since this is large, please
continue on petsc-maint at mcs.anl.gov
Matt
> Chris
> dr. ir. Christiaan Klaij CFD Researcher Research & Development *MARIN
> * 2, Haagsteeg C.Klaij at marin.nl P.O. Box 28 T +31 317 49 39 11 6700 AA
> Wageningen F +31 317 49 32 45 T +31 317 49 33 44 The Netherlands I
> www.marin.nl
> MARIN webnews: <http://www.marin.nl/web/show/id=46836/contentid=2240> MARIN’s
> Ships Hydrodynamics Seminar in Brazil
> This e-mail may be confidential, privileged and/or protected by copyright.
> If you are not the intended recipient, you should return it to the sender
> immediately and delete your copy from your system.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090303/d444522b/attachment.htm>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090303/d444522b/attachment.jpeg>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090303/d444522b/attachment-0001.jpeg>
