Smoother settings for AMG
Matthew Knepley
knepley at gmail.com
Wed Jul 29 16:22:39 CDT 2009
On Wed, Jul 29, 2009 at 4:17 PM, BAYRAKTAR Harun <Harun.BAYRAKTAR at 3ds.com>wrote:
> Matt,
> It is from the pressure poisson equation for incompressible navier-stokes
> so it is elliptic. Also on 1 cpu, I am able to solve it with reason able
> iteration count (i.e., 43 to 1.e-5 true res norm rel tolerance). It is the
> parallel runs that really concern me.
Actually, it was the 43 that really concerned me. In my experience, an MG
that is doing what it is supposed
to on Poisson takes < 10 iterations. However, if your grid is pretty
distorted, maybe it can get this bad.
Matt
> Thanks,
> Harun
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Matthew Knepley
> *Sent:* Wednesday, July 29, 2009 5:00 PM
> *To:* PETSc users list
> *Subject:* Re: Smoother settings for AMG
> On Wed, Jul 29, 2009 at 3:54 PM, BAYRAKTAR Harun <Harun.BAYRAKTAR at 3ds.com>
> wrote:
> Hi,
> I am trying to solve a system of equations and I am having difficulty
> picking the right smoothers for AMG (using ML as pc_type) in PETSc for
> parallel execution. First here is what happens in terms of CG (ksp_type)
> iteration counts (both columns use block jacobi):
> Are you sure you have an elliptic system? These iteration counts are
> extremely
> high.
> Matt
> cpus | AMG w/ ICC(0) x1 | AMG w/ SOR x4
> 1 | 43 | 243
> 4 | 699 | 379
> x1 or x4 means 1 or 4 iterations of smoother application at each AMG
> level (all details from ksp view for the 4 cpu run are below). The main
> observation is that on 1 cpu, AMG w/ ICC(0) is a clear winner but falls
> apart in parallel. SOR on the other hand experiences a 1.5X increase in
> iteration count which is totally expected from the quality of coarsening
> ML delivers in parallel.
> I basically would like to find a way (if possible) to have the number of
> iterations in parallel stay with 1-2X of 1 cpu iteration count for the
> AMG w/ ICC case. Is there a way to achieve this?
> Thanks,
> Harun
> AMG w/ ICC(0) x1 ksp_view
> KSP Object:
> type: cg
> maximum iterations=10000
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> PC Object:
> type: ml
> MG: type is MULTIPLICATIVE, levels=3 cycles=v, pre-smooths=1,
> post-smooths=1
> Coarse gride solver -- level 0 -------------------------------
> KSP Object:(mg_coarse_)
> type: preonly
> maximum iterations=1, initial guess is zero
> PC Object:(mg_coarse_)
> type: redundant
> Redundant preconditioner: First (color=0) of 4 PCs follows
> KSP Object:(mg_coarse_redundant_)
> type: preonly
> maximum iterations=10000, initial guess is zero
> PC Object:(mg_coarse_redundant_)
> type: lu
> LU: out-of-place factorization
> matrix ordering: nd
> LU: tolerance for zero pivot 1e-12
> LU: factor fill ratio needed 2.17227
> Factored matrix follows
> Matrix Object:
> type=seqaij, rows=283, cols=283
> total: nonzeros=21651, allocated nonzeros=21651
> using I-node routines: found 186 nodes, limit used is
> 5
> linear system matrix = precond matrix:
> Matrix Object:
> total: nonzeros=9967, allocated nonzeros=14150
> not using I-node routines
> Matrix Object:
> type=mpiaij, rows=283, cols=283
> total: nonzeros=9967, allocated nonzeros=9967
> not using I-node (on process 0) routines
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object:(mg_levels_1_)
> type: richardson
> Richardson: damping factor=0.9
> PC Object:(mg_levels_1_)
> type: bjacobi
> block Jacobi: number of blocks = 4
> Local solve is same for all blocks, in the following KSP and PC
> objects:
> KSP Object:(mg_levels_1_sub_)
> type: preonly
> PC Object:(mg_levels_1_sub_)
> type: icc
> ICC: 0 levels of fill
> ICC: factor fill ratio allocated 1
> ICC: using Manteuffel shift
> ICC: factor fill ratio needed 0.514899
> Matrix Object:
> type=seqsbaij, rows=2813, cols=2813
> total: nonzeros=48609, allocated nonzeros=48609
> block size is 1
> Matrix Object:
> type=seqaij, rows=2813, cols=2813
> total: nonzeros=94405, allocated nonzeros=94405
> Matrix Object:
> type=mpiaij, rows=10654, cols=10654
> total: nonzeros=376634, allocated nonzeros=376634
> Up solver (post-smoother) on level 1 -------------------------------
> type: richardson
> type: bjacobi
> objects:
> type: preonly
> type: icc
> Matrix Object:
> block size is 1
> Matrix Object:
> Matrix Object:
> Down solver (pre-smoother) on level 2 -------------------------------
> KSP Object:(mg_levels_2_)
> type: richardson
> PC Object:(mg_levels_2_)
> type: bjacobi
> objects:
> KSP Object:(mg_levels_2_sub_)
> type: preonly
> PC Object:(mg_levels_2_sub_)
> type: icc
> ICC: factor fill ratio needed 0.519045
> Matrix Object:
> type=seqsbaij, rows=101164, cols=101164
> total: nonzeros=1378558, allocated nonzeros=1378558
> block size is 1
> Matrix Object:
> type=seqaij, rows=101164, cols=101164
> total: nonzeros=2655952, allocated nonzeros=5159364
> Matrix Object:
> type=mpiaij, rows=411866, cols=411866
> total: nonzeros=10941434, allocated nonzeros=42010332
> Up solver (post-smoother) on level 2 -------------------------------
> type: richardson
> type: bjacobi
> objects:
> type: preonly
> type: icc
> Matrix Object:
> block size is 1
> Matrix Object:
> Matrix Object:
> Matrix Object:
> AMG w/ SOR x4 ksp_view
> KSP Object:
> type: cg
> PC Object:
> type: ml
> post-smooths=1
> type: preonly
> type: redundant
> type: preonly
> type: lu
> matrix ordering: nd
> Matrix Object:
> 5
> Matrix Object:
> Matrix Object:
> type: richardson
> Richardson: damping factor=1
> maximum iterations=4, initial guess is zero
> type: sor
> SOR: type = local_symmetric, iterations = 1, omega = 1
> Matrix Object:
> type: richardson
> type: sor
> Matrix Object:
> type: richardson
> type: sor
> Matrix Object:
> type: richardson
> type: sor
> Matrix Object:
> Matrix Object:
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090729/59760b10/attachment.htm>
