Smoother settings for AMG
BAYRAKTAR Harun
Harun.BAYRAKTAR at 3ds.com
Wed Jul 29 16:17:12 CDT 2009
Matt,
It is from the pressure poisson equation for incompressible
navier-stokes so it is elliptic. Also on 1 cpu, I am able to solve it
with reason able iteration count (i.e., 43 to 1.e-5 true res norm rel
tolerance). It is the parallel runs that really concern me.
Harun
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Wednesday, July 29, 2009 5:00 PM
To: PETSc users list
Subject: Re: Smoother settings for AMG
On Wed, Jul 29, 2009 at 3:54 PM, BAYRAKTAR Harun
<Harun.BAYRAKTAR at 3ds.com> wrote:
I am trying to solve a system of equations and I am having
difficulty
picking the right smoothers for AMG (using ML as pc_type) in
PETSc for
parallel execution. First here is what happens in terms of CG
(ksp_type)
iteration counts (both columns use block jacobi):
Are you sure you have an elliptic system? These iteration counts are
extremely
high.
Matt
cpus | AMG w/ ICC(0) x1 | AMG w/ SOR x4
1 | 43 | 243
4 | 699 | 379
x1 or x4 means 1 or 4 iterations of smoother application at each
AMG
level (all details from ksp view for the 4 cpu run are below).
The main
observation is that on 1 cpu, AMG w/ ICC(0) is a clear winner
but falls
apart in parallel. SOR on the other hand experiences a 1.5X
increase in
iteration count which is totally expected from the quality of
coarsening
ML delivers in parallel.
I basically would like to find a way (if possible) to have the
number of
iterations in parallel stay with 1-2X of 1 cpu iteration count
for the
AMG w/ ICC case. Is there a way to achieve this?
Harun
AMG w/ ICC(0) x1 ksp_view
KSP Object:
type: cg
maximum iterations=10000
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
PC Object:
type: ml
MG: type is MULTIPLICATIVE, levels=3 cycles=v, pre-smooths=1,
post-smooths=1
Coarse gride solver -- level 0 -------------------------------
KSP Object:(mg_coarse_)
type: preonly
maximum iterations=1, initial guess is zero
divergence=10000
PC Object:(mg_coarse_)
type: redundant
Redundant preconditioner: First (color=0) of 4 PCs
follows
KSP Object:(mg_coarse_redundant_)
type: preonly
maximum iterations=10000, initial guess is zero
divergence=10000
PC Object:(mg_coarse_redundant_)
type: lu
LU: out-of-place factorization
matrix ordering: nd
LU: tolerance for zero pivot 1e-12
LU: factor fill ratio needed 2.17227
Factored matrix follows
Matrix Object:
type=seqaij, rows=283, cols=283
total: nonzeros=21651, allocated nonzeros=21651
using I-node routines: found 186 nodes, limit
used is
5
linear system matrix = precond matrix:
Matrix Object:
total: nonzeros=9967, allocated nonzeros=14150
not using I-node routines
Matrix Object:
type=mpiaij, rows=283, cols=283
total: nonzeros=9967, allocated nonzeros=9967
not using I-node (on process 0) routines
Down solver (pre-smoother) on level 1
KSP Object:(mg_levels_1_)
type: richardson
Richardson: damping factor=0.9
divergence=10000
PC Object:(mg_levels_1_)
type: bjacobi
block Jacobi: number of blocks = 4
Local solve is same for all blocks, in the following KSP
and PC
objects:
KSP Object:(mg_levels_1_sub_)
type: preonly
divergence=10000
PC Object:(mg_levels_1_sub_)
type: icc
ICC: 0 levels of fill
ICC: factor fill ratio allocated 1
ICC: using Manteuffel shift
ICC: factor fill ratio needed 0.514899
Matrix Object:
type=seqsbaij, rows=2813, cols=2813
total: nonzeros=48609, allocated nonzeros=48609
block size is 1
Matrix Object:
type=seqaij, rows=2813, cols=2813
total: nonzeros=94405, allocated nonzeros=94405
Matrix Object:
type=mpiaij, rows=10654, cols=10654
total: nonzeros=376634, allocated nonzeros=376634
Up solver (post-smoother) on level 1
type: richardson
divergence=10000
type: bjacobi
and PC
objects:
type: preonly
divergence=10000
type: icc
Matrix Object:
block size is 1
Matrix Object:
Matrix Object:
Down solver (pre-smoother) on level 2
KSP Object:(mg_levels_2_)
type: richardson
divergence=10000
PC Object:(mg_levels_2_)
type: bjacobi
and PC
objects:
KSP Object:(mg_levels_2_sub_)
type: preonly
divergence=10000
PC Object:(mg_levels_2_sub_)
type: icc
ICC: factor fill ratio needed 0.519045
Matrix Object:
type=seqsbaij, rows=101164, cols=101164
total: nonzeros=1378558, allocated
nonzeros=1378558
block size is 1
Matrix Object:
type=seqaij, rows=101164, cols=101164
total: nonzeros=2655952, allocated nonzeros=5159364
Matrix Object:
type=mpiaij, rows=411866, cols=411866
total: nonzeros=10941434, allocated nonzeros=42010332
Up solver (post-smoother) on level 2
type: richardson
divergence=10000
type: bjacobi
and PC
objects:
type: preonly
divergence=10000
type: icc
Matrix Object:
nonzeros=1378558
block size is 1
Matrix Object:
Matrix Object:
Matrix Object:
AMG w/ SOR x4 ksp_view
KSP Object:
type: cg
PC Object:
type: ml
post-smooths=1
type: preonly
divergence=10000
type: redundant
follows
type: preonly
divergence=10000
type: lu
matrix ordering: nd
Matrix Object:
used is
5
Matrix Object:
Matrix Object:
type: richardson
Richardson: damping factor=1
maximum iterations=4, initial guess is zero
divergence=10000
type: sor
SOR: type = local_symmetric, iterations = 1, omega = 1
Matrix Object:
type: richardson
divergence=10000
type: sor
Matrix Object:
type: richardson
divergence=10000
type: sor
Matrix Object:
type: richardson
divergence=10000
type: sor
Matrix Object:
Matrix Object:
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090729/1b912f36/attachment-0001.htm>
