Smoother settings for AMG
BAYRAKTAR Harun Harun.BAYRAKTAR at 3ds.com
Wed Jul 29 16:48:50 CDT 2009
Matt,
Sorry, I thought you meant the ones with iteration counts in the
hundreds. I had a typo it was 46 actually (not 43). That's very
interesting that you think it should converge in less than 10
iterations, all I can say is I wish I could get there. This mesh is a
graded mesh and does have some poor aspect ratio elements. For a uniform
mesh I see 20 iterations or so.
Harun
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Wednesday, July 29, 2009 5:23 PM
To: PETSc users list
Subject: Re: Smoother settings for AMG
On Wed, Jul 29, 2009 at 4:17 PM, BAYRAKTAR Harun
<Harun.BAYRAKTAR at 3ds.com> wrote:
	Matt,
	It is from the pressure poisson equation for incompressible
navier-stokes so it is elliptic. Also on 1 cpu, I am able to solve it
with reason able iteration count (i.e., 43 to 1.e-5 true res norm rel
tolerance). It is the parallel runs that really concern me.
Actually, it was the 43 that really concerned me. In my experience, an
MG that is doing what it is supposed
to on Poisson takes < 10 iterations. However, if your grid is pretty
distorted, maybe it can get this bad.
  Matt
	Harun
	Sent: Wednesday, July 29, 2009 5:00 PM
	On Wed, Jul 29, 2009 at 3:54 PM, BAYRAKTAR Harun
		I am trying to solve a system of equations and I am
having difficulty
		picking the right smoothers for AMG (using ML as
pc_type) in PETSc for
		parallel execution. First here is what happens in terms
of CG (ksp_type)
		iteration counts (both columns use block jacobi):
	Are you sure you have an elliptic system? These iteration counts
are extremely
	high.
	  Matt
		cpus    |       AMG w/ ICC(0) x1        |       AMG w/
SOR x4
		1       |               43              |
243
		4       |               699             |
379
		x1 or x4 means 1 or 4 iterations of smoother application
at each AMG
		level (all details from ksp view for the 4 cpu run are
below). The main
		observation is that on 1 cpu, AMG w/ ICC(0) is a clear
winner but falls
		apart in parallel. SOR on the other hand experiences a
1.5X increase in
		iteration count which is totally expected from the
quality of coarsening
		ML delivers in parallel.
		I basically would like to find a way (if possible) to
have the number of
		iterations in parallel stay with 1-2X of 1 cpu iteration
count for the
		AMG w/ ICC case. Is there a way to achieve this?
		Harun
		AMG w/ ICC(0) x1 ksp_view
		KSP Object:
		 type: cg
		 maximum iterations=10000
		 tolerances:  relative=1e-05, absolute=1e-50,
divergence=10000
		 left preconditioning
		PC Object:
		 type: ml
		   MG: type is MULTIPLICATIVE, levels=3 cycles=v,
pre-smooths=1,
		post-smooths=1
		 Coarse gride solver -- level 0
		   KSP Object:(mg_coarse_)
		     type: preonly
		     maximum iterations=1, initial guess is zero
divergence=10000
		   PC Object:(mg_coarse_)
		     type: redundant
		       Redundant preconditioner: First (color=0) of 4
PCs follows
		     KSP Object:(mg_coarse_redundant_)
		       type: preonly
		       maximum iterations=10000, initial guess is zero
divergence=10000
		     PC Object:(mg_coarse_redundant_)
		       type: lu
		         LU: out-of-place factorization
		           matrix ordering: nd
		         LU: tolerance for zero pivot 1e-12
		         LU: factor fill ratio needed 2.17227
		              Factored matrix follows
		             Matrix Object:
		               type=seqaij, rows=283, cols=283
		               total: nonzeros=21651, allocated
nonzeros=21651
		                 using I-node routines: found 186 nodes,
limit used is
		5
		       linear system matrix = precond matrix:
		       Matrix Object:
		         total: nonzeros=9967, allocated nonzeros=14150
		           not using I-node routines
		     Matrix Object:
		       type=mpiaij, rows=283, cols=283
		       total: nonzeros=9967, allocated nonzeros=9967
		         not using I-node (on process 0) routines
		 Down solver (pre-smoother) on level 1
		   KSP Object:(mg_levels_1_)
		     type: richardson
		       Richardson: damping factor=0.9
divergence=10000
		   PC Object:(mg_levels_1_)
		     type: bjacobi
		       block Jacobi: number of blocks = 4
		       Local solve is same for all blocks, in the
following KSP and PC
		objects:
		     KSP Object:(mg_levels_1_sub_)
		       type: preonly
divergence=10000
		     PC Object:(mg_levels_1_sub_)
		       type: icc
		         ICC: 0 levels of fill
		         ICC: factor fill ratio allocated 1
		         ICC: using Manteuffel shift
		         ICC: factor fill ratio needed 0.514899
		             Matrix Object:
		               type=seqsbaij, rows=2813, cols=2813
		               total: nonzeros=48609, allocated
nonzeros=48609
		                   block size is 1
		       Matrix Object:
		         type=seqaij, rows=2813, cols=2813
		         total: nonzeros=94405, allocated nonzeros=94405
		     Matrix Object:
		       type=mpiaij, rows=10654, cols=10654
		       total: nonzeros=376634, allocated nonzeros=376634
		 Up solver (post-smoother) on level 1
		     type: richardson
divergence=10000
		     type: bjacobi
		objects:
		       type: preonly
divergence=10000
		       type: icc
		             Matrix Object:
nonzeros=48609
		                   block size is 1
		       Matrix Object:
		     Matrix Object:
		 Down solver (pre-smoother) on level 2
		   KSP Object:(mg_levels_2_)
		     type: richardson
divergence=10000
		   PC Object:(mg_levels_2_)
		     type: bjacobi
		objects:
		     KSP Object:(mg_levels_2_sub_)
		       type: preonly
divergence=10000
		     PC Object:(mg_levels_2_sub_)
		       type: icc
		         ICC: factor fill ratio needed 0.519045
		             Matrix Object:
		               type=seqsbaij, rows=101164, cols=101164
		               total: nonzeros=1378558, allocated
nonzeros=1378558
		                   block size is 1
		       Matrix Object:
		         type=seqaij, rows=101164, cols=101164
		         total: nonzeros=2655952, allocated
nonzeros=5159364
		     Matrix Object:
		       type=mpiaij, rows=411866, cols=411866
		       total: nonzeros=10941434, allocated
nonzeros=42010332
		 Up solver (post-smoother) on level 2
		     type: richardson
divergence=10000
		     type: bjacobi
		objects:
		       type: preonly
divergence=10000
		       type: icc
		             Matrix Object:
nonzeros=1378558
		                   block size is 1
		       Matrix Object:
nonzeros=5159364
		     Matrix Object:
nonzeros=42010332
		 Matrix Object:
		   total: nonzeros=10941434, allocated nonzeros=42010332
		AMG w/ SOR x4 ksp_view
		KSP Object:
		 type: cg
divergence=10000
		PC Object:
		 type: ml
pre-smooths=1,
		post-smooths=1
		     type: preonly
divergence=10000
		     type: redundant
PCs follows
		       type: preonly
divergence=10000
		       type: lu
		           matrix ordering: nd
		             Matrix Object:
nonzeros=21651
limit used is
		5
		       Matrix Object:
		     Matrix Object:
		     type: richardson
		       Richardson: damping factor=1
		     maximum iterations=4, initial guess is zero
divergence=10000
		     type: sor
		       SOR: type = local_symmetric, iterations = 1,
omega = 1
		     Matrix Object:
		     type: richardson
divergence=10000
		     type: sor
omega = 1
		     Matrix Object:
		     type: richardson
divergence=10000
		     type: sor
omega = 1
		     Matrix Object:
nonzeros=42010332
		     type: richardson
divergence=10000
		     type: sor
omega = 1
		     Matrix Object:
nonzeros=42010332
		 Matrix Object:
experiments is infinitely more interesting than any results to which
their experiments lead.
	-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090729/32587ba5/attachment-0001.htm>
