Solver problem
Tim Kroeger
tim.kroeger at cevis.uni-bremen.de
Wed Jul 29 03:33:30 CDT 2009
Dear Barry,
On Tue, 28 Jul 2009, Barry Smith wrote:
>> undefined symbol: _gfortran_allocate_array
> This is likely a symbol in the gfortran compiler libraries.
> Are you linking your application code against all the libraries it needs to
> be linked against?
Thank you for your help. It seems I have found the reason now. It
has to do with the cluster I am working on: The operating system on
the master (where I compile my application) does not coincide with the
system on the nodes (where the application is run). That is, e.g.
/usr/lib/libgfortran.so differs between these installations. I will
ask the cluster's admin for assistance.
Best Regards,
Tim
Dr. Tim Kroeger
tim.kroeger at mevis.fraunhofer.de Phone +49-421-218-7710
tim.kroeger at cevis.uni-bremen.de Fax +49-421-218-4236
Fraunhofer MEVIS, Institute for Medical Image Computing
Universitaetsallee 29, 28359 Bremen, Germany
