PETSC debugger
Ryan Yan vyan2000 at gmail.com
Sun Jul 19 13:47:23 CDT 2009
Dear Berend,
Thanks for your suggestion.  I can see that option right there!!
However, I am still struggling to find a way to turn this option off as I
can see from
vyan2000 at vyan2000-linux:/etc/gdm$ ps -ef | grep /usr/bin/X
root      5287  5285  3 14:19 tty7     00:00:42 /usr/bin/X :0 -br -audit 0
-auth /var/lib/gdm/:0.Xauth -nolisten tcp vt7
I am using Ubuntu *gnome*, but there is no such gdmrc file that I can
correct. I tried several other ways, but have not succeed yet.
vyan2000 at vyan2000-linux:/etc/gdm$ uname -a
Linux vyan2000-linux 2.6.24-24-generic #1 SMP Tue Jul 7 19:46:39 UTC 2009
i686 GNU/Linux
I am still searching....
Yan
On Sun, Jul 19, 2009 at 2:59 AM, Berend van Wachem <
b.van-wachem at imperial.ac.uk> wrote:
> Dear Ryan,
> I had a similar issue as you have. I am using KDE as a desktop manager and
> found that I have to comment out the line
> "ServerArgsLocal=-nolisten tcp"
> in kdm, in the kdmrc file (on my system located at /etc/kde/kdm/kdmrc).
> After restarting kdm, I get all windows of gdb coming up.
> Regards,
> Berend.
> Ryan Yan wrote:
>> I do not have acess to linux right now, I will check it as the first thing
>> tomorrow.
>>  Yan
>> On Sun, Jul 19, 2009 at 12:54 AM, Barry Smith <bsmith at mcs.anl.gov<mailto:
>> bsmith at mcs.anl.gov>> wrote:
>>     Are you sure the other window isn't lurking away somewhere off (or
>>    nearly) off the screen?
>>     Maybe try shutting down the x server and restarting?
>>     Barry
>>    On Jul 18, 2009, at 11:50 PM, Ryan Yan wrote:
>>        Thank you very much, Barry.
>>        After I use the vyan2000-linux:0.0, I got errors without any gdb
>>        window.
>> :~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/ttt2$
>>        mpirun -np 2 ./rpisolve -ksp_monitor_true_residual
>>        -start_in_debugger -display vyan2000-linux:0.0
>>        [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26518
>>        on display vyan2000-linux:0.0 on machine vyan2000-linux
>>        [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26519
>>        xterm Xt error: Can't open display: vyan2000-linux:0.0
>>        Then
>>        I changed back,
>>        -start_in_debugger -display :0.0
>>        Same as before, error messages with only a single gdb window,
>>        (and the window shows up at different place at different
>> instances).
>>        Yan
>>        On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith
>>        <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>         Try using -display vyan2000-linux:0.0
>>         Shouldn't make any difference but since it appears you are
>>        running everything on the same machine what you have given
>>        should work.
>>         Barry
>>        On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
>>        Hi All,
>>        I am tring to use the PETSc runtime option -start_in_debugger.
>>        However, when I attach the debugger at run time to each process,
>>        there are error messages and I only get one gdb window(Am I
>>        suppose to get as many as the number of the processes?)
>>        [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307
>>        on display :0.0 on machine vyan2000-linux
>>        [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306
>>        Then, only a *single* gdb window prompts out. When I run with 3
>>        process, there are only *two* gdb windows.
>>        Thank you very much in advance,
>>        Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090719/b71e32b0/attachment.htm>
