PETSC debugger
Berend van Wachem
b.van-wachem at imperial.ac.uk
Sun Jul 19 13:52:22 CDT 2009
Dear Ryan,
I am not a Gnome user, but a colleague of mine suggested:
For Gnome you should edit the file /etc/gdm/gdm.conf
and change the settings:
DisallowTCP=false
Berend.
Ryan Yan wrote:
> Dear Berend,
> Thanks for your suggestion. I can see that option right there!!
> However, I am still struggling to find a way to turn this option off as
> I can see from
> vyan2000 at vyan2000-linux:/etc/gdm$ ps -ef | grep /usr/bin/X
> root 5287 5285 3 14:19 tty7 00:00:42 /usr/bin/X :0 -br -audit
> 0 -auth /var/lib/gdm/:0.Xauth -nolisten tcp vt7
> I am using Ubuntu *gnome*, but there is no such gdmrc file that I can
> correct. I tried several other ways, but have not succeed yet.
> vyan2000 at vyan2000-linux:/etc/gdm$ uname -a
> Linux vyan2000-linux 2.6.24-24-generic #1 SMP Tue Jul 7 19:46:39 UTC
> 2009 i686 GNU/Linux
> I am still searching....
> Regards,
> Yan
> On Sun, Jul 19, 2009 at 2:59 AM, Berend van Wachem
> <b.van-wachem at imperial.ac.uk <mailto:b.van-wachem at imperial.ac.uk>> wrote:
> Dear Ryan,
> I had a similar issue as you have. I am using KDE as a desktop
> manager and found that I have to comment out the line
> "ServerArgsLocal=-nolisten tcp"
> in kdm, in the kdmrc file (on my system located at /etc/kde/kdm/kdmrc).
> After restarting kdm, I get all windows of gdb coming up.
> Regards,
> Berend.
> Ryan Yan wrote:
> I do not have acess to linux right now, I will check it as the
> first thing tomorrow.
> Yan
> On Sun, Jul 19, 2009 at 12:54 AM, Barry Smith
> <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>
> <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>> wrote:
> Are you sure the other window isn't lurking away somewhere
> off (or
> nearly) off the screen?
> Maybe try shutting down the x server and restarting?
> Barry
> On Jul 18, 2009, at 11:50 PM, Ryan Yan wrote:
> Thank you very much, Barry.
> After I use the vyan2000-linux:0.0, I got errors without
> any gdb
> window.
> vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/ttt2$
> mpirun -np 2 ./rpisolve -ksp_monitor_true_residual
> -start_in_debugger -display vyan2000-linux:0.0
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid
> 26518
> on display vyan2000-linux:0.0 on machine vyan2000-linux
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid
> 26519
> xterm Xt error: Can't open display: vyan2000-linux:0.0
> Then
> I changed back,
> -start_in_debugger -display :0.0
> Same as before, error messages with only a single gdb window,
> (and the window shows up at different place at different
> instances).
> Yan
> On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith
> Try using -display vyan2000-linux:0.0
> Shouldn't make any difference but since it appears you are
> running everything on the same machine what you have given
> should work.
> Barry
> On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
> Hi All,
> I am tring to use the PETSc runtime option
> -start_in_debugger.
> However, when I attach the debugger at run time to each
> process,
> there are error messages and I only get one gdb window(Am I
> suppose to get as many as the number of the processes?)
> 26307
> on display :0.0 on machine vyan2000-linux
> 26306
> Then, only a *single* gdb window prompts out. When I run
> with 3
> process, there are only *two* gdb windows.
> Thank you very much in advance,
> Yan
