PETSC debugger
Berend van Wachem
b.van-wachem at imperial.ac.uk
Sun Jul 19 01:59:58 CDT 2009
Dear Ryan,
I had a similar issue as you have. I am using KDE as a desktop manager
and found that I have to comment out the line
"ServerArgsLocal=-nolisten tcp"
in kdm, in the kdmrc file (on my system located at /etc/kde/kdm/kdmrc).
After restarting kdm, I get all windows of gdb coming up.
Berend.
Ryan Yan wrote:
> I do not have acess to linux right now, I will check it as the first
> thing tomorrow.
> Yan
> On Sun, Jul 19, 2009 at 12:54 AM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> Are you sure the other window isn't lurking away somewhere off (or
> nearly) off the screen?
> Maybe try shutting down the x server and restarting?
> Barry
> On Jul 18, 2009, at 11:50 PM, Ryan Yan wrote:
> Thank you very much, Barry.
> After I use the vyan2000-linux:0.0, I got errors without any gdb
> window.
> vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/ttt2$
> mpirun -np 2 ./rpisolve -ksp_monitor_true_residual
> -start_in_debugger -display vyan2000-linux:0.0
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26518
> on display vyan2000-linux:0.0 on machine vyan2000-linux
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26519
> xterm Xt error: Can't open display: vyan2000-linux:0.0
> Then
> I changed back,
> -start_in_debugger -display :0.0
> Same as before, error messages with only a single gdb window,
> (and the window shows up at different place at different instances).
> Yan
> On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith
> <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
> Try using -display vyan2000-linux:0.0
> Shouldn't make any difference but since it appears you are
> running everything on the same machine what you have given
> should work.
> Barry
> On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
> Hi All,
> I am tring to use the PETSc runtime option -start_in_debugger.
> However, when I attach the debugger at run time to each process,
> there are error messages and I only get one gdb window(Am I
> suppose to get as many as the number of the processes?)
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307
> on display :0.0 on machine vyan2000-linux
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306
> Then, only a *single* gdb window prompts out. When I run with 3
> process, there are only *two* gdb windows.
> Thank you very much in advance,
> Yan
